Hi all,
I just dropped and replaced the front seal in my '85 Ford Bronco II transmission.
It has the first year A4LD transmission in it.
I believe it specs Dex II ATF for it.
I picked up a jug of Super Tech High Mileage ATF for it last night.
I plan on starting with this fluid, but my question is with the requirements of Dex II I assuming not being so stringent, will I benefit from using newer speced fluid?
My options would be to use the Valvoline Dex/Merc, Valvoline Maxlife, or Super Tech ATF's.
It is difficult for me to wrap my head around Maxlife covering so many different ATF's, I am thinking maybe simple is better for this trans.
I plan on doing a pan drop and filter change every 30,000 miles.
It has a factory cooler, but I might upgrade it to a size bigger.
I appreciate any feedback.
