Originally Posted By: dnewton3
- suitable for just about everything, except a Powerstoke ... but I digress
That you have to use Delvac 1 LE 5w30 for, since that E6 lube is on the previous iteration of the list, despite being a low P lube, but I digress, too.
please tell me that you'll run it longer than 10k kms (lie to me if you must, so I can sleep well tonight).
I'm not sure what intervals I'm going to run it at. I suspect that if I got used oil analysis done, the Multi-Vehicle 5w30 would go significantly longer than 10,000 km, considering its starting TBN of 11.
Guys, Dave isn't being a wet blanket. It may come off that way, but he's simply pointing out that this lube has obvious capabilities for extended drains. And let's be honest here. Who really wouldn't want to know how far it can go? 5,000 and 10,000 km aren't even the slightest challenge, generally speaking, to a high TBN, enhanced HTHS lubricant, unless one has a fuel system just loading up that oil and never got up to temps.
ZZMan is set for a while, too!
For the Canadians here who are interested, NAPA Canada can likely get it in, too, as it's on their website. Their price is a bit higher than it should be, but not insane; that's just NAPA for you and they do get specials. The distributor is probably the best bet.
LoneRanger: There may be more than one reason why there is no dexos1 approval, but the most obvious is that the HTHS is too high for ILSAC approval. With respect to dexos2 approval (i.e. Chevy Cruze diesel), the HTHS is right, but the SA is too high. The specifications met by this lubricant are mutually exclusive to dexos1 and dexos2.
