Synthetic 15w-40 vs 5w-40
Exactly.
Not sure why CAFE was brought up in this thread. Neither grade is resource conserving.
CAFE was brought up earlier to make a point about thick vs thin protection. I believe it was due to the CAFE standards making OEMs look toward thinner as a solution to meet standards. This is of course possibly at the expense of protection depending on the engine we are talking about and how much the design shears oil.
It's 5.9 cummins! Put some 15w40 and forget it. I've used Delvac Super 1300 15w40 for over 100k with changes every 5k. I maybe get two oil changes a year and I never had any oil related issues. Purrs the same as the day I got it.
FF in DMax ….?
5W-40 all things equal is inferior to a 15w40 due to the thinner base oil blend and the viscosity improvers needed. That being said and as mentioned the 5W wil lbe better below 0*f for cold pumpability. I use 5W-40 in my tractor because I change oil once a year and I want the cold pumping in the winter if there is a cold spell and the temps drop well below freezing and I need to clear the road or something..
I agree 100%.
I know that T6 5w40 has a HUGE following, but it has not performed well in my motorcycles and more recently in my EcoDiesel. Yep, I think this issue is the viscosity improvers and the oil shearing in certain engines and driving conditions.
I have two oils that I am tossing around for my next fill.....
Rotella T5 10w30 (Semi-Synthetic)
Rotella T6 15w40 (Full-Synthetic)
But I think I am done with 5w40 oils.
I agree 100%.
You could be right. In comparison, let us know how the T5 10w30 and T6 15w40 oils work for you.
HTHS is different, 15w40 index is better than 5w40, 15w40 is less reliant on viscosity index improvers.
15w40's also have much higher content in calcium, phosphor, zinc, and so fourth.
i have read many times of motorcyclists trying a 5-40 only to quickly DUMP it when shifting gets poor, especially with shared oil supplies. unlike redlines 15-40 that acts like a 10W when cold according to specs wide viscosity spreads dont do well. interesting link about thinner-thicker oils, a nice read enforcing my love for thicker oils!!
That may not be true. For example, as I posted previously, Mobil shows using Group II+ to blend an HDEO 10w30 (similar spread to 15w40), additives are 20%
Here's a 0w-40, 5w-40 and 10w-40, same 20% additive content in the 5w-40 as the 15w40:
Heavier one in this table, 20.7%, 8.7% being VII:
Compare to a Group III 5w-40 where VII load is 11.8% for the "balanced" formula:
Another HDEO, this 10w-40 has 9.8% VII using Group II+, more than our 5w-40 Synthetic above:
I'll see if I can dig up one that specifically covers a 15w40.
That may not be true. For example, as I posted previously, Mobil shows using Group II+ to blend an HDEO 10w30 (similar spread to 15w40), additives are 20%View attachment 78931
I commented a while back that 10W40 would be a good HDEO spread for N America
OK, here's a 15w40, you can see that your typical Group II variant is ~20% VM+DI, similar to the 10w30 I showed earlier, and the 5w-40 synthetic:
