E3 plug condition after 45K miles
Kentucky
My weekend plans went out the window (due to VERY poor weather forecasting) so I had some extra time on my hands and unanticipated awesome weekend weather.
Installed some E3 spark plugs around 125K miles on my '07 Pacifica. Vehicle just turned over 170K, I decided to pull them early (about 45K on the plugs) to assess the condition, mostly out of curiosity. I don't usually buy "fancy" spark plugs but they were on closeout at Rockauto for less than a $1 a piece at the time. Fairly certain they claim a 100K service life.
My initial thought is that they're still in decent shape and would probably go 75K or so, but I'd be quite wary running them to 100K, mostly because of the center electrode being so rounded off. That said, I've seen non platinum/iridium/etc plugs that have gone the distance, like the Champion copper plugs used in many Chrysler Hemi motors-- I've seen them so wore down at 100K that the center electrode had worn beneath the porcelain, and still be firing. So these E3 could likely make it to 100K as the manufacturer claims, but I opted to change them anyways, since I had new plugs already on hand. Used Autolite Iridium XP plugs at about $5 a plug.
Required removing intake, but fortunately it comes off in about 15 minutes on this car-- a hose clamp, half dozen wire connectors, couple vacuum/PCV hoses to pull off, then about 8 bolts and it's out. All in all I think the E3 is a good plug but I can't say it did anything magical that would make a large price premium worth it.
At only 45k? I would hard pass those plugs in the future. My 17 Subaru 3.6 NGK's at 105k IIRC...they looked great but there was center electrode wear to be seen. I could be wrong but they do not inspire confidence for me. Others may have a professional opinion to offer. Interested to hear the thoughts.
One has to keep in mind the E3 plug has an ordinary center electrode, no platinum tip or fancy metals. Not sure if that has benefits or not, but certainly not for longevity.
This ^^^^^^^^^^^^^^^. Those look awful. Best to use an oem spec plug. NGK or Denso. I prefer NGK.
FWIW, the OE plugs for your 2007 Pacifica seem to be NGK Laser Platinum. They'd still look better than that after 45k. Even the Autolites you put in should be good to 100k.
Yep, the original NGK plugs came out at 125K when I did the timing belt service and installed the E3 plugs. The NGKs were still in reasonably good shape. I think the moral of the story is E3 and exotic plugs aren't worth the extra $. But at $0.80 a piece I got my money's worth, but nothing more than that.
I get that there's a natural reaction to condemn E3 plugs because of their inflated marketing and claims to do magic (like better burn, fuel economy, etc.) But in the interest of discussion, aside from usual wear on the center electrode (rounded off), what is so wrong with them after 45K? I seriously debated putting them back in. If I were to pull the "copper" Denso plugs out of my '96 Maxima that have 30K or so on them, I'd expect to see the same thing.
I get it that you can put a set of double platinums, iridium, ruthenium, etc in and they'll still have a nice sharp point after 100K with a COP ignition system.
But all I see is a worn plug typical of 45K miles use, not a "bad plug" per se. Correct me if I'm wrong? Looks like nice normal deposits also, granted there's much more of it due to the extra ground electrode surface area.
When I think of worn out spark plug, I envision this: (credit given to #tyman, I borrowed his image from another post). I've seen a LOT worse plugs that were still working fine. If it were an older vehicle with say, a distributor ignition system (or older single coil for all plugs style) I'd say the rounded off corners could be an issue because of the higher voltage required to bridge the gap.
At least Nissan was smart enough to put cutouts in the intake so the spark plugs are easy :D
When I had it, I put Denso iridium in, a nice upgrade over the factory spec NGK Laser Platinum that cost the same price.
But since the job is easy on that maxima, a good compromise between price and longevity is the NGK G-Power (single platinum)
You're not kidding. But the old VQ30DE had a pretty simple aluminum intake (until you have to take it off haha), long runners, just had to cast an opening in between on the rear bank for the three plugs-- some engineer was using their head.
The plastic intake on the 4.0L Chrysler V6 has a variable intake with manifold tuning valves, which look to me like stepper motors that vary the amount of air that goes straight through vs what goes through a longer runner. Bit more elaborate and likely harder to put holes in the middle of :)
I'm not complaining about the lost time using copper and/or E3 plugs on either. One is a 25 minute job (thanks Nissan for the access holes!), the other maybe 45 minutes plus a $5 intake plenum gasket.
My Kia on the other hand, I'll use 100K plugs every time, I don't care if they cost $20+ a piece. That's an intake and maze of wires / hoses that looks like absolutely no fun to remove.
I only use e3 in my 2 stroke tools. Riding mower, blowers, chainsaws and ETC. But for some reason I just don't want to put them in my car.
They are a gimmick plug and plain copper - I see absolutely no benefits to using them when your vehicle came with and specs a long life plug (i.e. platinum/iridium/etc). Had the correct plug been installed you would not be replacing them now. I had a customer bring me a set of E3s to install in her 2002 Trans Am Ws6 - O'rielly guy forced them on her as the best plugs made. I installed them under her insistance and instant misfires - I took them out and replaced them with a correct set and everthing good. I just don't like these plugs - now if they were platinum or iridium then maybe I could see some worth in the price of them but as copper? No way. You basically got the life out of them as you would any other cheap copper plug that cost a few bucks.
There's been a dozen or more different new plugs over the decades that claim to work magic (pulstar, E3, etc.)--- the only magic happening has been sucking money out of people's wallets. The fact that nearly all vehicle manufacturers have settled on plugs using long lasting thin tip/wire using precious metals (e.g iridium, platinum) speaks volumes. If there was some magic plug like E3 or others that would benefit in fuel economy (extremely important due to CAFE), or power (still important), they would have adopted them by now.
The fact you missed is that I didn't pay a few bucks. They were $0.80 a piece on closeout, a nice experiment on a car whose plugs are easy to change. I had zero issues during their service life. I have no doubt they would have lasted another 30K+ given my experience with Hemi engines and others that use standard copper plugs to 100K+ given what the used plugs looked like. Cost per mile, I think I did just fine.
I did read that but didn't factor that in my reply so that's my bad - I do apologize. I actually think that was a worthwhile experiment and appreciate you sharing that info.
Easy to change.........
LMAO Sure....easy. Something I would want to do as often as possible for sure. Did you change the intake gasket or re-use? Cause that should be added to the cost of the job.
I'm with you, don't misunderstand. I get it was an experiment and without experiments how would we gain knowledge. Did you track your mileage over that time and see if you got their claimed increase?
No idea how you would, those plugs are ridiculous. The extra weight of all that metal for the ground is a performance hit alone before you get to the design issues. You're $0.80 price is a feat, they currently are sold for $9 each and I am assuming that is exclusively to recent brain surgery patients at that price.
There is a reason why 99.9% of regular plugs come with a single electrode.
Yes, exactly. If alternative electrode designs provided a proven benefit in unmodified engines, a benefit that was worth the money and effort, everyone would be using them AND they would be recommended more often by OEMs. Marketing works.
that was only 102k miles too but on a worked hard 6.0l 2500
