It should be at least 2,000lbs or more. That’s the range of a normal MGB.It says power, 70 kW which is about 94 HP. I couldn't find total weight, but if 0-60 is in 8.7 secs as they say, then total weight must be in the neighborhood of 1636 lbs. That's very light, and it's probably heavier than that, which means their 0-60 time is optimistic.
Put differently, 0-60 in seconds is usually about half the pounds / HP ratio. 8.7 doubled is 17.4, times 94 HP = 1636 lbs.
That said, the MGB was never about 0-60 time or P/W ratio.
To be fair you don't want to hustle an MG too hard anyway.They faithfully recreated the lousy performance.
I’ve found several with Chevy 350’s in them. Also an MGB with a Chevy 350. It’s actually not that tight in there.Well, hot rodders put 327s in Austin Healeys
You might want to mention that to these guys.To be fair you don't want to hustle an MG too hard anyway.
