Dual Flow oil filters?
Seen them before...never once, ever, heard of anyone actually using one, though. I'd expect the cost of paying for a new filter every single time for the little added benefit of a bypass filter would be tricky to justify.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2556562#Post2556562
that is the question that I had as well
I have been running the 7317 on my dodge for a few months and my oil stays visibly cleaner longer into the oil change
have not done an uoa
I did contact Baldwin and talk to their tech dept and compare flow ratings for this filter and the stock filter and since the flow ratings were favorable I am trying it
Baldwin dealers are much less expensive that grainger
ymmv
jim
have not done a uoa
jim
I have!
2000 Cummins 11 Ltr ISM powered motorhome. 3k miles & 15 mths on oil, LF9080 ff filter, and LF3542 bypass filter. 86k miles total on engine since new.
Code:
WEAR METALS(ppm)
Iron 6
Chromium 0
Copper 0
Tin 0
Lead 0
Nickel 0
Alum 0
Tin 0
Silver 0
Cadmium 0
Vanadium 0
CONTAMINANT METALS(ppm)
Silicon 5
Sodium 1
Potassium 0
MULTI SOURCE METALS(ppm)
Magne 0
Titan 0
Molybdenum 0
Antim 0
Mang 0
Lith 0
Boron 3
ADDITIVE METALS(ppm)
Magnes 9
Calcium 3666
Barium 0
Phosph 1199
Zinc 1376
CONTAMINANTS
Fuel Dilution
Soot Vol
Water
FLUID PROPERTIES
V100C(cSt) - 14.5
Oxidation(abs/cm) - 58
Nitration(abs/0.1 mm) - 6
TBN(mg KOH/g) - 9.40
Originally Posted By: EyesofThunder
Wow, that is a nice UOA! I might have to look into this one. How well does TBN hold up with a bypass vs none? Does it make a big diff?
Don't know? I never did a UOA before going with this setup. Sorry
