hello everyone
my question is :
i have Mitsubishi l200
manual ask for
hypoid 75w90 gl-4 transmission and transfer case
i'm having hard time to get gl4 only ...
can i use dual gl4/gl5 oils ? for example Total Traxium Dual 9 FE 75W90
it stays for syncro or non syncro gear boxes
and also for the differential (with no LSD)
can i use 80w90 LS? (oil for lsd difs )
is it ok? or should i search 80w90 regular (non lsd ) ?
i see that this Total Traxium Dual 9 FE 75W90 is for both gl4/gl5
but people say that they still use this "reactive sulfur additives" which over time will slowly damage and eat up the syncrho yello metal.
there is no way to know for sure the amount they put in but for this oil to be as well fit the gl5 i guess its higher then gl4 only oil ?
thank you
my question is :
manual ask for
thank you
