Originally Posted By: Audi Junkie
So, if I used a wireless (G) router like the one I have here in a box, I would need a wireless card for *both* of the computers? I can't just plug one of the computers into the router w/ the CAT5 or Ethernet cable and get the wireless card for just the remote computer???
Thanks for your advice.
I'm looking at the actual unit...
It has the yellow cable for "the internet" and four more marked "LAN". So, maybe they just plug into the wired computer(s). Ok, well I'm not at the office now, but at least I looked at it. Thanks again.
Wireless router include ethernet ports that you can plug CAT 5 cable to, I prefer wired option and I frequently used wireless router in wired only configuration. The best wireless is still not as reliable as even the oldest wired configuration.
For your next appt connection, you can run a router that is set as an access point (or buy an access point) and let all the computers in that apt go through this access point. I use DD-WRT on various router and turn them into access point/bridge and they all work much better than a wireless card, due to better antenna design and the ability to locate them at the optimal location in the house (i.e. near window between homes or in the attic).
My neighbor and I are sharing a cable modem connection and the line is at his house. I pay him 1/2 the cost per month and have a router turned access point connect to his network, then another wireless router re-broadcast the signal in the house. Perfect signal every day for the last 6 months, and a $25 saving over having my own line.
