- Joined
- Sep 2, 2016
- Messages
- 984
We inherited an old Whirlpool dryer from the 60/70s (240V 30A). It's been fine with some upkeep - replacing the thermostats, belt (new old stock), etc. The biggest issue I have with it is the screw down wire lug/connectors; they seem to loosen up overtime from movement, resulting in a loose connection, higher resistance and eventually burnt/melted wires. The first instance was at the heating element, and now one of the live wires melted at the terminal strip that bonds the plug wiring to the machine wiring. I noticed that some connections were folded-over stranded wiring with the screw down lugs, while the stranded wiring was soldered solid at other connections. "Technicians" have been through this machine in the past, so I'm not sure what's original and what's been hacked together as a fix.
Anyway, I'm not crazy about this type of screw down connector, especially with stranded wiring. What is the best way to prevent this from happening again? Solder the stranded wiring solid and reuse the terminal block? Bypass the terminal block with Wagos? Wago 221-612 is rated for 600V, 30A and 10-20 AWG wiring.
