Originally Posted By: JHZR2
Coolant? ATF? Diff fluids? Brake fluid? timing belt? Accessory belt? likely pads and rotors by then? Battery?
All of the fluids will have been changed long before 100k miles. The coolant has 4 years on it, so it'll be changed before 100k miles also. There is no timing belt on this engine (chain). The accessory belt might need changing by then, I don't know. That's a $20 part. Battery's already been done.
If you keep a car a LONG time, yes, all that will be done. But, starting at 50k means that youre 50k closer to needing to do it.
Yes, this is true. No argument there. But none of that comes close to the money saved up front. I could do everything on your list for $2,000 easy, including struts and shocks. I still have at least $2,000-4,000 in the bank after that (depending on whatever rate you choose to use for the new car loan).
You can argue that the operating cost/mile may go up buying used but you have a $4,000-6,000 savings to subsidize that.
In the end, SOMEBODY has to pay for depreciation on the new car. The rate of depreciation is highest in the first few years of ownership, and Hondas are no exception to that. Hondas have a low depreciation, but I don't think it's quite as low as some make it out to be.
Again, I'm not trying to talk you into a used car. Everyone's situation is different, and different people will get the best value for them doing it some ways vs. others.
