Driving me nuts.... really a problem or am I being too picky?
Ar
I have a 97 Grand AM with the 2.4L DOHC engine. Today I had to replace the braket that holds part of the intake on. Got the new (used) one which ended up breaking too..... anyway I had it welded back together and re-installed everything.
On startup I was greeted with white smoke. Let it idle some to warm up and it didn't help. I did notice it was dripping water from the tailpipe, is it safe to assume this smoke was condensation and nothing else? If so, how did it get in there? It's 70F outside!
I took it for a drive through the mountains, including 4,500RPM climb in 2nd gear.
Ran fine and strong.
Got back, parked, let it idle and there was no smoke, just a strong exhaust smell.
One other thing I've noticed seperately from what I mentioned above is that if I rev the engine it reves freely and easily but the exhaust sounds like it can't keep up, almost like the engine is chugging but it isn't. Any ideas to what could cause that? I have modified the intake some, so could it be that's just a restrictive exhaust?
White smoke sounds like a blown head gasket. Did you say you modified the intake? Have you removed the intake? Are you sure you got the intake sealed?
[ October 13, 2003, 07:37 PM: Message edited by: sbc350gearhead ]
Didn't smell sweet...no loss of coolent. First time I've ever seen it really. The headgasket was replaced less than a year ago when I had the water pump done (gotta remove *everything* to get to that sucker).
Once it was warmed up and ran hard both the water and "smoke" went away. I just let it sit 2 hours and start it again.... no "smoke" of any kind.
I left the intake apart for about 4 hours while my bracket was bieng fixed, could that have had anything to do with it? Maybe it got moisture in it from sitting?
By modified it I only took off the air silencer for less restriction and better sound, no biggie there.
Pretty sure it's sealed back up good. Runs good, and I couldn't feel any air being sucked from places it shouldn't be.
Seems like once you get a leak, you can never get rid of it.
[ October 13, 2003, 07:43 PM: Message edited by: goldfinger ]
