2005 camry. Had the following symptoms:
1. Drivers door window stopped working after overnight park in garage.
2. When key is taken from ignition, the "auto" light on the drivers window switch flashes - on, off, on, off, off, repeat.
3. This continues until the delay in power supply switches off automatically.
4. Disconnected battery for 5 mins.
5. When key was switched to on and taken from ignition again, "auto" light on switch did not flash but was lit up continuously.
6. When auto down detent is pushed for more than a few seconds the "auto" light goes out and starts the blinking cycle again.
To me it looks like there is a circuit breaker kicking out in the door panel. I checked the fuse in the driver's dash compartment, it's ok.
Have the car booked at dealer tomorrow, but would appreciate some advice.
