Driveline vibrations.
Indiana
This is with my Chevy Blazer. 218k miles. I’ll get a driveline vibration immediately upon acceleration that will go away until 40 mph or so and then mostly go away after that. The low speed vibration IMO rules out an unbalanced wheel. I want to say a bad u joint, but I’m not seeing anything obvious there play wise. Revving in neutral doesn’t do anything either so I’m also ruling out motor mounts.
Thanks in advance.
Under acceleration means either it’s the transmission mount, or it’s in your driveshaft. Check U - joints, center bearing if you’ve got one…
What year is the Blazer?
That's when you're putting the most torque on it. It is possible you have a tired u joint that just isn't doing enough under normal circumstances. But something else is worn (engine mount, leaf spring bushings) thats causing either the transmission or axle to move enough that it makes the u joint unhappy.
1997. The S10 style. (Not the GMT400 2 door Tahoe.)
U-Joints most likely. It's not lifted or lowered or anything anything is it? That can change angles enough to induce vibration. It's also surprising how much sagging engine mounts and transmissions mounts can change the angle of the tailshaft, so I would certainly look at all that stuff.
  • Like
Reactions: wlk
