Drive Belt Date Code
CA
Can anyone decipher the date code on this aftermarket Mitsuboshi drive belt?
I believe "Z913" is the date code.
This is a low volume application so parts availability can be an issue - and stuff tends to be old stock.
That is no problem for EPDM rubber. 50 years is not out of the question in some applications.
In that case, are you suggesting that I leave the 8 year, 25k old belt in service? This is in a Previa, so the belts are quite removed from the normal heat exposure of an engine.
Went ahead and installed the new belts - they were supposedly mfg'ed in 2018 and 2019 in different plants. The new belts were harder than the belts I removed, not sure if that means anything.
I use new but aged accessory belts; I usually buy them ahead of time and never get around to installing them right away.
The only belts I don't let "age" are Ducati timing belts. More of a paranoia thing (expensive if they let go).
