I'm getting ready to install a Hollow bolt on a transmisson pan and I was wondering instead of punching the hole with a 5'16 punch why don't I just drill it with a 5'16 drill. Any one try this.
I'm guessing metal chips in the oil pan, and the "pushed in" (embossed) metal will give more area for the threads to grab, as too why they recommend punching.
Tempest is right. A drilled hole isn't as strong as a punched hole. Not enough metal for the threads to bite into. A punched hole doesn't put metal particles in the pan.
It is always best to use a sharp punch and put it into a pair of vise grips. Punch a small hole first and put a wire in it to make sure there is nothing like an oil pump. That way if you have to plug a hole you don't have to plug a large one. Keep punching the hole a little at a time until it is about 5/16". Watch out for spot welds. It might mean something is welded inside the pan such as reinforcement or baffling. My Nissan diesel has a bunch of stiffeners welded to the inside of the pan. I punched a hole in a Volvo oil pan once that was so hard to punch I made the pan gasket start leaking. Some are so thin that one blow of the hammer and it's done.
I did a Ford Ranger with the V-6 that had the aluminum oil pan. I put the self tapping hollow bolt in the valve cover very close to the fill cap. Most people want the sandwich adapter these days. I remember when they came out with the spin on filters. It was a big improvement. Now they are making my life difficult with cartridge filters. I converted my old Honda road bike to take a spin on filter then installed a two port sandwich adapter and a Ford spin on filter.
