Went against my better judgement and bought this:
http://www.oreillyauto.com/site/c/detail...8&ppt=C0142
This is on a 4L80E I think 7.5-8 quarts pan capacity. The inner bolt is leaking, the outer piece seems fine with the nylon washers. The inner bolt only came with a flimsy rubber o-ring. Couldn't get it stop leaking with the o-ring so I tore it out and cinched the bolt down. You can still see the ATF coming around the bolt, hasn't dripped in 2 hours though. Going to check it in the morning but I see a drop I'll be at a cross roads.
Is there anything viable to stop the leak without draining the 8 quarts? RTV? Not even sure I can find a nylon or copper washer. Draining those 8 quarts won't be fun!
