Call me mad, but I never really saw the point of doing a simple drain and refill...especially considering the torque converter is where much of the fluid is held and you're just draining what's in the transmission.
Whenever I service my transmissions (generally every 25,000 miles), I always take the time to do a cooler line flush, drop the pan, replace the filter and the gaskets, clean them out and fill up to the correct level. 10,000 kilometres (6,250 miles) prior to the service, I dump in half a bottle of ARX as well. My transmission's capacity in the Pajero/Montero, for instance, is 7.2 litres and I usually use about 12 litres or so to flush it all out.
I've recently had people telling me this causes more harm then good. Considering you're dumping out the old fluid for new, and immediately notice an improvement in shift quality afterwards, I do not see how. Having said that, does a cooler line flush (at the recommended intervals) help extend the life of a transmission, because the old fluid is completely being replaced with fresh fluid regularly?
Just a random thought. Thanks.
