Well , after reading on this forum , I have been using the turkey baster , from time to time .
Presumably not reading (or at least not believing) the bit where it says the "turkey baster method" is pretty useless. I doubt its completely useless, since it may protect your master cylinder a bit, but its likely to leave some wet fluid in the extremities where it can cause corrosion and interfere with braking.
Seems to be doing a little good , since the ABS lite is coming on less often .
I have done brake work many times ( starting back in the late 1960's ) & Wifey has helped bleed the brakes many times ( since the 1980's ) . Think we will be good in that area .
Wifey is out of town visiting oldest Grand Daughter . Will try to flush the system when She gets back , & can help . Hope the little Bleed nipples are not rusted solid ...........
You don't need help (unless your wife is good at freeing up rusted bleed nipples, which is a pain).
Wives may be different (no experience) but having tried girlfriends in the brake bleeding role I'd say it isn't worth the collateral hassle.
There are several ways you can bleed brakes solo. Easiest is probably a simple gravity bleed, though I personally favor using an enema syringe for more pressure and control.
