Bad picture! It's tough to tell, but it doesn't even look like your hinge is mortised into the door and frame.
It's also tough to tell what your door is constructed out of. Maybe a veneer or composite material with particle board frame??
Either way, I suppose my first try would be a longer, larger screw that has a head that would still fit in the hinge countersink. It might grab, or not.
The other option is to rebuild the stripped out hole. One way is to take some solid wood (match,golf tee,dowel) put wood glue on them and drive them into the old hole. When dry, predrill the hole and install the original or better hinge screws.
A worse case alternative is to drill out the old hole oversized and glue a wood dowel into it, then predrill the holes into the dowel and remount the hinges.
Lots of Youtube videos about this. Maybe something new, better, and easier!
