REFORMULATED FOR EVEN BETTER PERFORMANCE: INTRODUCING CASTROL EDGE WITH SYNTEC POWER TECHNOLOGY.
For years, you’ve depended on the power of Castrol SYNTEC to outperform conventional motor oils. Now, we’ve reformulated SYNTEC to outperform even itself:
New, powerful dispersant molecule suspends particles to fight power-robbing deposits [2]
Improved formula continues to keep the engine running at peak power longer [1]
Castrol EDGE with SYNTEC Power Technology performs better than conventional oil in the toughest industry tests
Superior protection against deposits. Corrosive particles such as acid, soot and oxidized fuel fragments can cause costly damage to critical engine parts
Powerful Additive Package that neutralizes corrosive particles, preventing them from grouping together and forming deposits.
Neutralizes acids in your engine that can cause rust and corrosion on vital engine parts such as cylinders, bearings and hydraulic valve lifters
Meets the world's toughest industry gasoline engine protection requirements [3]
Provides Stability & Endurance under extreme conditions (heat, load, speed) that can cause conventional oils to break down
Delivers the ultimate performance under high-temperature conditions: unsurpassed protection against volatility burn-off and viscosity increase
Can be used with confidence in every gasoline engine passenger car, new or old, regardless of oil previously used [4]
Fully compatible with all conventional and synthetic oils
CASTROL HAS TAKEN EDGE TO THE NEXT LEVEL
For over 100 years, Castrol has been the technology leader in motor oil. In 2009, Castrol once again raised the bar for motor oil by launching a new, advanced synthetic called Castrol EDGE. Now, we proudly introduce our most advanced motor oil ever: Castrol EDGE with Titanium Fluid Strength Technology.
Why is it Castrol’s most advanced motor oil?
In extreme tests, Castrol EDGE with Titanium Fluid Strength Technology maintained maximum horsepower 60% longer than Castrol SYNTEC[1]
Power = strongest dispersants to fight power-robbing deposits
Performance = strongest oxidation control to provide longest wear protection
Protection = Lowest volatility for maximum performance during the entire drain interval
An advanced proprietary formula that provides performance and protection in extreme conditions such as towing, hauling, high and low temperatures, rapid acceleration and stop-and-go traffic [2]
Performance and protection that outperforms conventional, high mileage and synthetic blend motor oils
Exceeds the world’s toughest industry-agreed standards [3]
