Originally Posted By: Corvette Owner
Originally Posted By: 440Magnum
Also, more power on a dyno does NOT necessarily mean less wear. Lubrication at the microscopic level is extremely complex and I'm no expert, but as I understand it there are friction modifiers that can reduce sliding friction without actually reducing metal removal. Conversely, there are anti-wear agents that reduce metal removal but may actually increase (slightly) friction.
Wow, I learned something from your last paragraph! I can see how ". . . there are friction modifiers that can reduce sliding friction without actually reducing metal removal. Conversely, there are anti-wear agents that reduce metal removal but may actually increase (slightly) friction."
Although, I must admit that I can understand how ". . . there are anti-wear agents that reduce metal removal but may actually increase (slightly) friction." better than ". . . there are friction modifiers that can reduce sliding friction without actually reducing metal removal." I have a tough time seeing how reduced friction could cause more wear?
Like I said, I'm no expert but my crude understanding is that the total friction at a sliding contact point comes from several sources, such as:
1 metal-to-metal contact (the actual wear process)
2 oil and friction modifier additive molecules grinding against each other and against the metal (not wear related)
3 sacrificial additives (eg. ZDDP) doing their thing (wear suppression)
4 lots of other stuff I don't understand (catch all
When you stop and think about it, *most* of the actual measurable friction has to come from source 2, or else engines would wear out in minutes instead of in years. So a little savings in #2 can actually dominate the total friction.
Given that, I can vaguely see how you could make a friction modifier additive combo that greatly reduce the friction of the oil and additive molecules against each other while not actually stopping the metal-to-metal contact. Net result: less friction at the sliding contact, but still the same wear.
