Donaldson equivalent for AC delco pf 52?
I've searched far and wide even using oil filter cross reference website and clicking the alternative (wix 51036) filter that has a ton of alternatives. I was hoping to get a solid recommendation to replace my Amsoil eao23 that's coming off soon. I am disappointed with Amsoil filter QC recently and have decided they aren't what they used to be (ahem...WIX/MH!). I have also searched the Donaldson website using the attribute search for their automated recommendations and have only seen P550051 recommended (99% efficient at 45 microns). Is this the best I can hope for? TIA.
Bud...I used to be this way and it honestly feels like losing a beloved pet.
I had some glue on the clean side of one of their cartridge style filters (15k04 specifically). I emailed...it was a whole thing.
Get the NAPA equivalent Oil Filter, the only Donaldson Oil Filter that is the best of the best is the blue media 1
The Napa Oil Filter is a 1056
@gasman556
why not just use a PF52?
I've never used any AC delco stuff. Is it good? I am coming from Motorcraft where getting OEM filters was a "NO GO" and am assuming all domestic OEM filters are equally trash.
I am looking for a Donaldson blue/synteq/whatever is their top tier filter media for this application (if even possible), but can't find it.
You think Napa gold 1056 is a solid choice? I used to use them without a second thought, but when they changed from Wix to PG I got weary (wrongly).
Here is the issue with Donaldson, they only offer the best oil filter media, meaning the Blue stuff in only a few oil filters. Donaldson then turns around and sells other oil filters that do not have the Blue Media. I have read that this Blue Media is 99% at like 17 Microns.
The Napa Gold 1056 is your best option.
I think off the shelf, the AC Delco are one of the best you can buy, IMO. I would and have used with confidence. PF52 or the champion equal........
https://www.rockauto.com/en/moreinfo.php?pk=11192613&cc=0&pt=5340&jsn=327
good and cheap.
I think off the shelf, the AC Delco are one of the best you can buy, IMO. I would and have used with confidence. PF52 or the champion equal........https://www.rockauto.com/en/moreinfo.php?pk=11192613&cc=0&pt=5340&jsn=327
good and cheap.
OK, good to know! Is the AC Delco line of filters suspect for any sort of bypass issues, torn media, excessive glue, etc?
Not that i am aware of. I have observed many, cut open after use, and never saw a flaw.......seen a bunch of debris, but never a flaw....good luck.
The PG made filter is better than the Mann-Hummel made NAPA filters.
PG filter better than Amsoil and ACDelco.
If you have an oreilly's auto try Microgard Select. Also the Purolator Boss still good filter if you want a WIX alternative with "smartfusion" reinforced media.
Think the OP is looking for an efficiency to be better than what the Boss or Wix XP would give.
