does this brake line or fitting exist?
https://www.speedingparts.com/p/bra...steel/brake-line-adapter-m10x1-male-male.html
Do you have room to curl the brake line 270 degrees?
it's a rear beam suspension with drum brakes. Working on a drum to rear disc setup. so the stock setup is hard brake line to soft brake line back to hard brake line to brake cylinder. i'm trying to do a hard brake line to soft brake line to 90 degree elbow or 180 degree U shape hard brake line to soft brake line to caliper.
I bet the answer is in using different rubber hoses with the same ends just cocked how you need them. In the old days you could fumble through boxes at the parts store. Now, you'd have to find some master catalog. Start with the disc brake option that got you those calipers.
the disc brake option that got me the calipers is a euro spec version so euro specific parts. i've been thinking and have 1 out of 4 iterations. i can use a longer line but need to fabricate a custom support bracket. this first option i was thinking about does not involve brackets, but i won't have to order from europe also.
You want as little length of rubber hose as you need for suspension articulation. Any more and the pedal might feel softer. Also ensure your master cylinder is compatible.
