Does Marvel Mystery Oil have any Oil in it?
Here
I checked a few MSDS’s I found on Google, and there is no mention of anything that looked like oil to me. But perhaps since the oil isn’t considered toxic or dangerous, it’s not on the MSDS?
I’m considering mixing MMO with FP: MMO for cleaning and FP for lubrication. But if MMO has oil in it, perhaps that would be too much oil…
Ok, my screen name will finally get some use. What??????????
Actually, Marverl Mystery OIL is pancake syrup disquised as an oil product so that only a select few (who know what it really is) can benefit from its' taste.
Just kidding.
Yes, it's oil & may be a bit much when used w/ FP unless only half of the recommended amount of each product were used.
Hmmm, it didn't have that slippery feel that FP has when I spilled some on my fingers...
quote:
Originally posted by GROUCHO MARX:
It doesn't taste like oil?
I can't answer that, but I can tell you that it doesn't smell like oil!
It's oil. I plugged up my water injection filter thinking adding a few drops to the water reservoir would help lubricate the inside of my supercharger when the water was misting. Duh... I'll never do that again.
MMO does smell good though doesn't it? I use it in two cars applied through inverse oilers, it is good stuff for sure.
Why would you consider mixing FC and MMO? If you have evaluated the chemistry of both and discovered something can you share it with us. We promise not to tell anyone else.
I just think that MMO does more cleaning than FP, and FP does more lubricating than MMO.
