My used oil analysis came up high in sodium when using Valvoline Synpower. Valvoline of course contains sodium, but my level was about 650ppm, which is higher than the amount Valvoline uses.
I did a leakdown test and could not find any evidence of a headgasket leak. I did a coolant system pressure test and found no obvious leaks other than a tiny radiator leak that has existed for 20 years.
If Castrol Edge does not contain sodium, I would like to give it a try to see if my levels remain elevated.
