I have a 2003 Dodge Caravan that I THOUGHT was rust free. The vehicle has very little rust as I rarely drive it in the winter. I just looked under the vehicle and the rear spring shackles are heavily rusted. The cussed things look like they spent 15 years in the ocean. I grabbed an old paintbrush and coated the shackles with Fluid Film. I plan to Fluid Film the underside to protect things like brake lines.
If you have a Dodge Caravan, check your rear spring shackles. Dodge apparently makes them from " rust while you watch " alloy. In fairness, Toyota uses this material for truck frames as well
