Originally Posted By: SHOZ
Originally Posted By: y_p_w
Originally Posted By: Globalksp
Thanks all for your thoughts.
I just changed the plugs on my '07 Fit with the factory spec NGK Laser Iridiums. Checked the gap and all were good except for one which was at .065" instead of the recommended .045-.051.
And here are plugs out of that Fit with 90,000 miles on them:
Most of these OEM "iridium" plugs are actually iridium on the center electrode and a platinum puck fused to the ground electrode. It seems kind of odd that these small precious metal electrodes improve on a bunch of things, but they do work pretty well. It's pretty basic - the platinum/iridium gets hot and self cleans, the clearest path is through those little tips, and these tiny pieces of metal resist erosion. It seems to avoid having the spark fire through the surface of the nickel alloy, which is probably the main reason for erosion of standard (I refuse to call them "copper") plugs.
All plugs including Iridiums have a copper core. No plugs have copper electrodes.
You'd be surprised how many supposed "experts" think that the electrodes materials exposed to the combustion chamber are made of copper. Copper would of course be gone in less than an hour it it was the exposed part of the electrode.
Quote:
https://www.carid.com/articles/types-of-spark-plugs.html
Copper Spark Plugs
Sometimes referred to as "standard" or "normal", copper-tipped spark plugs are lower in cost and have the shortest lifespan due to copper’s naturally tendency to erode away over time. However, their value lies in the ability of copper to conduct electricity better than any other type of material used on spark plug tips. As a result,
copper-tipped plugs run cooler, and deliver more power in performance driving applications without reaching overheated temperatures which reduce power and shorten spark plug life.
http://carandbiker.co/best-spark-plugs-reviewed/
Copper Spark Plug
This type of spark plug is typically referred to as a standard version of a spark plug. The reason that these variations shine is that the copper on the device is great for conducting the electricity; in fact, it is the best conductor that you can have on a spark plug. If you are looking for an efficient spark plug, the
copper tipped plugs are the best option. Since the electricity is easily conducted, the spark plug will not overheat as quickly, which means that the life of the spark plug will be extended. Copper does naturally erode, so the lifespan of this type of spark plug will always be limited, which is why they are often very inexpensive to purchase. These copper tipped spark plugs will typically last between 20,000 miles and 40,000 miles before a problem arises.
There is of course a whole lot of wrong that becomes "common knowledge". One is that copper is used in the core because it's the best electrical conductor (outside of silver). It is, but that means little when nearly all plugs contain a resistor to reduce electromagnetic interference, and the gap of air creates way more "resistance" than the plug. Copper is used to conduct heat from the core.
