Someone on the internet told me, that todays cars are NOT meant to charge up a battery, they are designed to MAINTAIN a battery charge. But I've never had a new battery that was not charged.
That's silly. As long as you have at least 10 amps of input the battery will charge at a good pace. But most economy cars and their economy alternators can give 30a easily. The problem is when the alternator is having to always do that and get stressed.Someone on the internet told me, that todays cars are NOT meant to charge up a battery, they are designed to MAINTAIN a battery charge. But I've never had a new battery that was not charged.
Personally, I would return a battery that was reading that low. Any voltage under 12.4 V or so will result in sulfation, and a battery at 12.08 V would have been sitting in that sulfating for a long time.Depends on the voltage. The new one I got that was 12.08v yes I did.
If you select a relatively fresh date-coded battery from the rack, why would you charge it?
When you buy a car that's been on the lot for a few months, do you run home, pull the battery, and charge it as well?
I did. The F-150 I bought in 2018 sat undriven on the lot for 5 months. When I got it home the battery was having issues. The battery was weak and would not show the screen and auto start stop would not trigger, power seats and windows were very sluggish and the radio would not play. I charged it overnight at 2 amps and it still was running at 1/2 amp for 12 more hours after it dropped from 2 amps, before going into float mode. After that no problems.If you select a relatively fresh date-coded battery from the rack, why would you charge it?
Nor have I.Nope, never have in 40 years of driving.
