- Joined
- Nov 29, 2009
- Messages
- 10,258
So this kind of goes along with my other thread of connecting one charger to dual 12v batteries connected in parallel and let the charge carry over to the other battery. Personally I think that's fine, but trying to do 4 batteries while only being directly connected to two seems a bit much. Now with that being said, I have a scissor lift and it has (4) 6v batteries wired in series to add up to 24v. Anyways, It has an onboard charger on it and it and i'm not sure they wired it up right, but only the two outer batteries are hooked up to the charger. After a while I noticed the case near the posts on the two outer batteries were swollen up. Maybe the charger was overcharging idk, because it's got something wrong with it too and I bought a new charger I need to install one of these days. why can't I connect charging wires to each battery? I could also be totally wrong and nothing could be wrong with the way they have it set up, but I've learned to not always trust that things were done correctly.
