I believe that a tire installer would still like to know if the vehicle owner has used a tire sealer in any of the tires.
So is that bead sealer in a can, but don’t get it on your clothes if you ever want to wear them in public again.Slime is awesome for lawn tractor tires.
It's almost impossible to get a patch or plug to seal once someone has put that stuff in there, even if you clean it out as good as you can.Back in the day, some fix a flat in a can products used flammable propellants. That's no longer the case but there are other reasons it's not good to leave in there long term. One being being the moisture can ruin your TPMS sensor. Another issue is that the leak is prone to return unless it's patched properly, tempting consumers to put additional cans of the stuff in.
Tire guys don't like it because it's messy and they have to take extra time to clean the tire, the rim and their equipment.
That's good to know.It's almost impossible to get a patch or plug to seal once someone has put that stuff in there, even if you clean it out as good as you can.
if the tech wants to know... they should ask.Whoever neglects to inform a tech that there's tire sealant in the tire deserves to be charged double labor. Was not fun breaking a tire off and having that garbage spill
Spoken like someone who hasn't ever worked on tires, good to know.if the tech wants to know... they should ask.
take a xanax princess! imma go get a latte from starbucks while u fix that tire MMMKAY???!!!!Spoken like someone who hasn't ever worked on tires, good to know.
Probably the same lazy person who expects a tech to dig through their trash-infested car for a wheel lock. Get over yourself.
