Do single weight oils have a place?
Single viscosity oils often have higher HTHS ratings. They may be a smart choice when extremely high temperatures are expected. They also may be less prone to shear, such as when used in a motorcycle with a shared transmission.
We use single viscosity oils in piston aircraft engines with good results.
Originally Posted by hatt
Originally Posted by expat
So assuming Jay Leno is being advised by someone knowledgeable, and expence is no real object, has anybody any idea why a 50 wt would be spec'd?
I think think the engine holds about 8 gallons!
Comparing vintage piston aircraft engines to modern econobox car engines is apples and donuts. Just what oil do you think he should use? TGMO 0w-20?
No! I assume the engine might require a 50 weight oil when hot.
But why would you want to subject it to a 50 weight oil when cold? (Yes, even California is cold when it comes to engine oil)
So considering the engine is low stressed and has a large oil capacity, why not good a 20W-50?
