Well, I finally found out from a corporate email that Peak Long Life antifreeze does infact contain 2-ethylhexanoate (aka it's a Dex-crud clone.) I'm in the process of flushing this junk out and changing over to Valvoline G05. In hind's sight, I can't believe I was dumb/cheap enough to skimp on buying an unknown coolant - should not buy it just cuz it's the best choice on the shelf! Luckily, I only had it in my car for 1-year/4000 miles. Although you can argue the chemistry of Dex-cool all day long, I'd rather pay an extra couple bucks for a safe, trusted blend instead of some GM-engineered garbage. We all know about the intake manifold and head gasket issues they've had for years, so why chance it with their coolant chemistry? With that in mind, I'd like to share a small list of safe/unsafe brands to run:
Safe:
- Any Japanese OEM fill
- Any European OEM fill
- Zerex G05
- Zerex original green - "low-silicate chemistry"
- Peak Global Lifetime
Unsafe:
- Any Dex-crud clone
- Any GM OEM fill
- Prestone "all makes" - another black sheep for the Dex-cruds
- Any generic brand - why chance it just to save a $ or two?
- Any high-silicate blend - these are becoming scarce though
As you can see, the coolants that I deem "safe" are also the harder, more expensive ones to find. Just remember, with a good flush it will last ya 5 years - so don't cut corners!!
Safe:
- Zerex G05
Unsafe:
- Any GM OEM fill
