Do new Jeeps have death wobble?
NH
Had a new-ish looking Jeep pass me this morning, only to slow down. I thought it odd, then realized a front wheel was shaking--then realized it was both, and that was why he had slowed down. I stopped to make sure he was fine, he was, he'd been driving it as a rental for the last day.
It wasn't a Cherokee, it was... Wranger? dunno, not a Jeep fan. Not one of the FWD things but a regular 4x4 setup, but not one of the upscale ones either.
Anyhow, death wobble or just flogged rental?
Either or both. You can get death wobble in brand new factory setup rigs that have no wear (and don't have a design defect), and of course a worn rig can have death wobble.
IIRC, there *were* a couple recent lawsuits about the Wrangler, alleging that recent versions have a design defect that causes death wobble and FCA released an updated steering damper to 'fix' it. I didn't ever look into the issue far enough to see if it was a "we're going to bandaid it with this damper" fix, "the damper is needed and will actually permanently correct it" fix, or if it was "there isn't a problem with the system, we're fitting a damper to make you idiots shut up" kind of fix.
Originally Posted by PowerSurge
Death wobble. Common with Jeeps and Rams with 4x4 and solid front axle.
It's pretty common in any solid front axle setup, some more than others - but it can affect IFS vehicles too. 4Runners like mine have a highly stressed lower ball joint setup that can cause death wobble when it wears. Uppers too, but they're less likely.
The older ones 90s - 2000 early types I had the displeasure to deal with I'll head a shimmy damper under the front center of the fan area. It looks like a small shock absorber mounted laterally. Whenever that thing wore out you knew it because it felt like the front end was going to fall off the thing. The only thing I ever saw worse for shaking it self to pieces and those grand Cherokees when The damper went out was a Cessna. Same sort of thing gets to a certain speed and you think that [censored] thing is going to fly apart.
Anyways if it's got any miles on it and it has one of those things you probably just wanna go ahead and change it because you're only like 35 $40 and real easy to put on. Jeeps are the only trucks that have those things and they all seem to have that same death wobble when it's worn out issue. I've pulled a few of them off and throw them away and they felt just fine but for whatever reason internally they weren't working right so if you're gonna bother taking it off just replace it
Jeeps are definitely not the only trucks that have steering dampers, my F-350 had one from the factory. Not even the only vehicles - the last GM B-body cars had them from the factory.
If they stick with a proper leaf sprung front end, they wouldn't death wobble. But anything that relies on the panhard bar for both lateral location and to keep the steering geometry in line is going to deathwobble. At least with leaves, the springs locate the axle.
If everything is in good shape, you do NOT need a steering stabilizer. My 2000 Cherokee with 214K miles doesn't even have one.
There's 2 ways to get out of death wobble. Stand on it and power through or slow down.
Cool, at least I didn't give the guy bogus info. It was a rental and I'm pretty sure I know how it'll get fixed.
Death wobble is common on solid front axle vehicles like the Wrangler when steering or suspension components are worn. Being a fairly new rental, it's likely it has been abused or someone hit something causing play in the steering.
Steering dampers are not the correct way to fix death wobble, and will only mask it for a short period of time.
My F-350 had front leaf springs. It had death wobble issues, so leaf springs aren't the answer either. It can help, buuuuut....
Negative. Its not from just when parts are worn. It's happening to Jeeps under warranty.
According to the Jeep Wrangler forum I moderate on, yes right up to the 2019's and IIRC a few 2020 owners have reported problems. Are all of them impacted? No... Some people have had repair attempts which didn't help either.
Many Mercedes have the front stabilizers on them. Macpherson strut front end. Doubt they are there for anything except to firm up reaction feedback into the steering wheel. Never had any death rattle on my Mercedes, even when I got it up to 145 MPH once. My knees rattled though. Published reports stated its top speed at 150+ mph and I believed it but never found that limit. There are a million videos on youtube showing fixes for the death rattle.
This.
It's a well-known artifact on anything with a solid front axle, but not exclusive to them.
Here's an article on the RAM heavy duty truck death wobble, he mentions he experienced it in a Lincoln Continental:
https://www.thurenfabrication.com/tech/death-wobble-in-depth.html
Here's a company selling a kit to eliminate the Super Duty death wobble:
https://www.superdutywobble.com/
And a Truck Trend article noting that while Death Wobble is more prevalent on Ford and Dodge/RAM trucks, it does happen on IFS trucks:
http://www.trucktrend.com/how-to/ch...death-wobble-tightening-up-your-steering
And here's a thread about it happening in an old 4Runner:
https://www.4runners.com/threads/1987-4runner-death-wobble-where-to-look-first.11827/
It's happening under warranty because the parts being used are likely junk or inadequate for the load put on them. Trust me, I've had way too many of these things apart. The death "wobble" itself is when the wheels violently shake back and forth. If you put a camera under the vehicle when this is happening, you can see the steering linkages (drag link, trackbar, possibly even lower control arms) shaking. The loose steering connections and slop in the joints is what causes the movement.
The issue is that it can be hard to detect which joints are bad, because even a small amount of play, which wouldn't be noticeable on any other vehicle, can be amplified and trigger death wobble. Things like unbalanced tires, poor alignment, pot holes, etc, can trigger it. The steering parts are either faulty from the factory, or the steering geometry is way off for the size of tires it is running.
I remember my BIL had death wobble in his 1998 Dodge 3500 dually. When it first happened I had not heard of it.
He told me, I took it for a ride nothing. Brought it back he said do it again...Scared the ever living BLEEP out of me.
I did some researched and we fixed it. Never had the problem again. It was the wildest thing.
Many Jeeps never experience it until they are lifted. The lift puts more strain on already worn steering parts and one little pothole can trigger the death wobble.
It happens a lot to Jeeps under warranty that are 100 percent bone stock. Fiat has lemon lawed many bone stock Jeeps over this.
How come Wranglers don't just use half shafts and independent front suspension? That's done on other body-on-frame vehicles, as my 4x4 F150 front end is like that. I used half metaphorically, the shaft length isn't a whole half length of the span. I get the need for a solid front axle on an HD truck, but Wranglers aren't heavy duty haulers. Does going to CV joints, short shafts, and independent suspension reduce off road superiority that much? I'm asking only because I don't know, not trying to be provocative.
