The Donaldson P502057 doesn't list a bypass rating ..but the Wix xref'd does. The Donaldson says Mazda as it's application (this is not the xref for a 6607 but is the same size, thread, and gasket diameter).
Here's the PH6607 xref'd to WIX
Part Number: 51365
UPC Number: 765809513655
Principal Application: Ford (92-97), Honda (00-05), Infiniti/Nissan (95-05), Mazda (97-05), Mercury (91-96), Subaru (88-05), Kia (94-05), Yanmar, John Deere, Kawasaki, Kobelco
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.577
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
P502057 (donaldson w/o bypass) x'ref'd to WIX
Part Number: 51357
UPC Number: 765809513570
Principal Application: Ford Probe (89-97), Mazda Cars & Trucks (83-96), Kia Sportage (95-02)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Gasket Diameters
This filter appears to be a little longer and has a lower bypass setting. I don't think that your engine has a built in bypass valve ...so I'd be careful in selection. The only risk that you take (in the opinions of a few) is potential damage to the media if it gets too clogged up.
