Originally Posted By: buickman50401
Originally Posted By: SuperFast
Also in matters of 5W20 i always say 5W30 since it as that extra layer of protection.
Not always and in some cases you're risking if not outright damage at least malfunction such as in variable displacement engines like the 5.7L Hemi which (gasp!) specs 5w20 because of the design of the valve train.
If you ran Xw30 in a Hemi will it grenade? No. Is the MDS system going to operate as designed (or at all?). No.
To understand how the system works read:
http://www.asashop.org/autoinc/oct2009/techtips.htm
Quote:
It's important to know this engine uses 5W-20 engine oil. If the wrong oil is used, fault code P1521 can be set, and the vehicle may show symptoms of a shudder - similar to a torque converter shudder - when the MDS system is activated and deactivated. Other symptoms may include MDS performance codes or engine misfire codes.
Before spending a lot of time with these codes, use the vehicle service history to find out what type of oil is in the engine. Because this is not always possible, the next best thing is to replace the oil (and filter) with 5W-20. This may have to be done twice to fully restore the system back to normal. Oil sludging, restricted oil passages or lifter contamination can also cause problems with this system.
I can appreciate that im jut saying i had 4 civics and put 5w30 in all of them the 1994 and ther 1997 (DX and EX) liked it the most and 5w30 was always perfect for a civic 4-banger since it never had a 6 and this change to specd for 5W-20 surprised me?
I was sharing my experience with the OP im not lying those civics ran great in 5w30 and that is the thickest it ever needed i promise OP that.
