Originally Posted By: razel
Originally Posted By: Ed_Flecko
Originally Posted By: javacontour
For DC, it uses the entire wire. With AC, you get some skin effect.
The reason to make stranded cable for DC is the ease of bending it. It makes no difference electrically in jumper cables, a DC application.
So, assuming the wire gauges were identical, you're saying that a cable made of a single, solid copper wire should flow just as much electricity as a cable made up of multiple copper wires?
So the only advantage the cable made of multiple strands has is that it's more flexible?
Ed
javacountour has already summarized it well and answered your question. No need to double check since brevity and simplification is a sign of deep knowledge.
If you double check his/her wisdom everyone else will just repeat or detail the reasons then it'll turn into rocket science. Well actually electricity is far more complex than rocket science. It's far more valuable too in our Information Age since electricity is it's blood.
Well hopefully you learned enough so you can make a wise decision over the price difference in a $20 vs. $40 jumper cable.
The $40 one is better, right?
Ed
