Do bypass filters reduce UOA usefullness?
Mr. Barton; Neither am I a blowhard, nor do I claim things that I cannot substantiate. I DO mean to disagree with you, I do NOT mean to be disagreeable. In all honesty, I think I could enjoy an Adult Beverage or two with you; although I also think we have some serious differences of opinion. That's OK; I'm man enough to let you be wrong. (YOU'RE SUPPOSED TO LAUGH AT THAT)
SAE Technical Paper 710813:
“In conclusion, this evaluation has shown the use of good full-flow filtration, combined with bypass lubrication oil filtration, will result in extension of engine wear life up to two to three times the wear life obtainable with only good full flow filtration. Therefore, the use of bypass oil filters result s in the overall lowest total cost to engine user.”
Technical Paper 660081
1966-02-01
J. A. Den Besten, E. G. Leverenz, C. M. Bloom
The addition of the radiotracer method of wear measurement to the tools available to the development engineer is a great aid, but not a pancea. Its use in conjunction with the conventional approaches can expedite development testing. If the test techniques are properly selected and combined, the ultimate answer can be partially predicted, alternatives screened, and backup engine tests made in a smooth flowing test sequence. Data from two unrelated product development programs are given as illustration. Indications are that piston ring wear predictability can be measurably improved.
SAE 912344: (Excerpt) Soot is the largest component of contaminants found in the diesel engine lubricating oil. The soot enters lubricating oil mainly through thermophoretic deposition on the cylinder wall. Although the mechanism is still not fully understood, it is generally accepted that soot particles promote engine wear, REDUCING ENGINE COMPONENT SERVICE LIFE, fuel efficiency and performance. This problem will be further exacerbated when more and more diesel engines use EGR to reduce NOx emissions and when lubricating oil consumption is drastically reduced to control particulate emissions.
SAE 881827: (Excerpt) Lube oil contamination is a PRIMARY REASON FOR ENGINE WEAR. The wear processes promoted by oil contamination lead to diminished fuel efficiency, shorter useful oil service life, REDUCED COMPONENT LIFE, and loss of engine performance. Contaminant particles responsible for this damage are in the size range of the dynamic lubricant films separating moving engine component surfaces: 10 microns and smaller. By making simultaneous contact with opposing surfaces these harmful particles focus the load onto a small area, degrading the surface. This paper reviews the nature of lubricant contamination, the modes of lubrication, and the primary mechanisms of engine wear. The correlation between contamination and wear of engine components, as well as several important studies quantifying the effect of contamination on engine wear and performance, are discussed. It is concluded that operating with clean lube oil, maintained by 10 micron filtration (β₁₀ ≻ 75), results in a diesel engine having better fuel economy, longer oil change intervals, superior performance, and GREATER DURABILITY.
SAE 881825: (Excerpt) The level of filtration in an engine can have a significant impact on wear rates due to abrasive particles. Tests were conducted to establish a relationship between the level of filtration and abrasive engine wear. Although the tests were run in a laboratory environment, wear was reduced by as much as 70% by going from a 40 micron filter to a 15 micron filter.
Testing was performed on a heavy duty diesel engine and later with an automotive gasoline engine. The results from both engines were consistent and showed that the relationship developed can be applied to nearly any internal combustion recipricating engine.
SAE 952555: Results show that a strong correlation exists between engine wear and the filtration efficiency of solid contaminant in the engine lube. It is clearly demonstrated that higher efficiency filtration results in cleaner lube oil and thus less engine wear.
OIL – HOW CLEAN DOES IT HAVE TO BE?
by: Mike Sondalini in collaboration with Don Irvine of Donamar Filters. Data supplied by Donamar Filters
Clean, dry oil can extend equipment life between failures up to 8 - 10 times the normal operating life. Timken, the bearing manufacturer, reports that reducing water levels from 100 ppm (parts per million) to 25 ppm increases bearing life 2 times. British hydraulics research indicate that if solids contamination with particles larger than 5 micron (0.005 mm or 0.0002”) is reduced from the range of 5,000 – 10,000 particles per milliliter of oil to 160 – 320 particles, the machine life is increased 5 times.
If you want extremely low wear rates and long equipment life the evidence indicates that oil needs to be filtered down to sub 5 micron size and preferably down to one micron size. Care needs to be taken that the filter does also not remove any solid additives, such as graphite, in the oil. Additives dissolved in the oil will not be removed unless the additive is attached to a solid particle.
I do agree with you that the average garage jockey who puts a BP on his one ton and commutes 30 minutes a day will never see any difference in wear. I'll take it a step further; depending upon his operating conditions, he may not even have his oil up to temperature in 30 minutes. I work with a couple of more experienced engineers who say that the two favorite answers from engineers are "Depends" and "Perhaps" All the variables must be stated or known.
Cheers.
It's Newton, not "Barton". No matter; I'm not offended - perhaps you were momentarily distracted. I do appreciate your candor and humor; this can be adversarial without being hateful. This can be a good learning experience for all, myself included, should new information come into play.
I'll note the extreme "age" of those studies you cite, the newest of which is 20 years old; one nearly 50 years old. Sir, things have changed, you know. Lubes and filters and even production manufacturing capabilites have made the "need" for super-fine filtration a thing of the past. I deal with current day data. I have to seriously quesiton any study that does not deal with current day modern engines. Diesel engines have come into common-rail, high-pressure, multi-event injection systems; these systems run MUCH MUCH cleaner in terms of soot because the combustion event is so much cleaner. Same goes for gasoline injection events; they too are MUCH cleaner than they were 20,30,40 years ago. My point is this; those studies are likely not relevant to today's diesel and gas engines. You really cannot expect to have a reasonable dialog with acient data. I would completely agree that a diesel engine from 1970 or 1980, using old-school single-squirt indirect injection (or two stroke such as some DDs) would have benefited from BP filtration relative to the filters of those decades. I can and do fully agree with that. But that is NOT relevant to today's engines, lubes or filters. Not at all. Between modern injection systems and excellent combustion chamber design, soot production is far less than it was even 20 years ago, therefore the main contributor to engine wear (hydrocarbon byproducts of incomplete combustion) is not on any predominate scale as it used to be. Therefore the studies relating to those "old" engines are not germane to this conversation.
While your list seems robust, I reserve my ability to read and fully research each document you indicate before continuing. Not unlike the infamous GM filter study, simply reading a synopsis can be VERY misleading. In short, what you've produced is a list of documents that may or may not be relevant due to age and or application.
I will ask this general question: have you actually read these studies, or did you just copy/paste the synposis of each from the SAE site? It seems your quotes have direct correlation to the outward points of the publically viewable canned marketing, and are not detailed or insightful. As I previously stated, one cannot simply read a glorified statement from the cover page and claim to understand the real data. For example, you make a direct word-for-word quote of these studies from the synopis page where one can purchase the study, but you don't disucss them in detail. Most folks think 88-1825 would support your point of view, but that study is completely worthless in terms of real world application; I have debunked that study previously here on this site. So, have you actually READ and ANALYZED these studies you cite for direct support of your claim, or are you just relying on the superficial conclusions posted on the SAE site?
As for the list you have provided - thank you. It will take me a while to review the full data within those documents, some of which I'll have to purchase. I would ask this of you; please indicate which ones you believe are MOST RELEVANT to your point, because I'm going to have to spend some money buying the studies, and I'm not going to purchase all of them. I have two already (71-0813 and 88-1825). Could you indicate perhaps which two others you can state that would significnatly substantiate your position? I'll spend some money, but I'm not made of money.
I just cannot agree with you that bypass filters do not reduce wear rates. Are you really going to say that if I have a given vehicle running a standard synthetic oil using a standard off the shelf filter (~50% @ 20 microns), that wear will not be any different than using a top tier synthetic (I use AMSOIL Signature Series) along with their dual layer synthetic full flow w/amsoil bypass BP90 filter element? Look at user Slalom44 and his S2000 with huge miles, you don't get that kind of mileage using standard lubrication without engine work.
I will be the first to admit that my bypass filter does not reduce wear in my CRV's engine, if it comes to that. But I am not really worried about that...
Mr. NEWTON,
Thank you for not taking offense; I absolutely assure you that none was or is intended. After reading several of your previous posts, I doubt that any information I post can change your mind; you seem to me to be firmly entrenched; but I love surprises.
I do not own all of the SAE papers I referenced, and I admit to copy and pasting their conclusions from their public summaries. The fact that you are not already familiar with all of them suggests to me that you are neither familiar with bypass filtration in general, since I got all the numbers from different bypass filter manufacturers websites. Nevertheless, apparently unlike yourself, I have no problems with 20-30+ year old information. To the best of my knowledge, 2+2 was 4 yesterday, and it will be 4 tomorrow.
There are entire industries built on principles that do not change. I work quality control in the power generation industry. We have been spinning turbines by burning coal in boilers to make steam to spin the generator since the 1940s. We have 13 separate power plants with bypass filtering on everything from the turbines to the coal mills and handling systems, to the water treatment plants; and we may have more "super-fine" systems in service than you have miles on your car.
Your statement of "Lubes and filters and even production manufacturing capabilites have made the "need" for super-fine filtration a thing of the past" I find incredulous to the point of disbelief. I, too, deal with current day data, and guys like me keep your lights on.
Since when has any "modern engine, common-rail, high-pressure, multi-event injection systems" managed to eliminate friction? The general question that I would like to ask of YOU is: Where in API specifications is there a standard for CLEANLINESS of new oil? If you cannot answer by referencing the specification per ASTM or API, just admit that either there is none or you don't know. I admit that I can find none.
Since friction cannot be eliminated, likewise, the generation of wear particles can neither be eliminated. Now let's put some real world numbers into this. One quart equals 946 ml. In a typical 5 quart automotive system, 5X946=4730ml. One quart of new motor oil having an ISO 4406 cleanliness code beginning with 19 (this is what I have documented) means that with a fresh oil change (which everyone is soo fond of), you have just introduced up to 5000 [per ml] TIMES 4730=23,650,000 particles of debris INTO the engine you're "trying" to take care of (of which an unknown quantity is silicon, or silicate, which is commonly known as ROCK). If anyone wants some really scary numbers, do the math on an 8 or 20 quart truck system. Why not just throw a shovel full of sand into your crankcase?
With my BYPASS filter system currently installed, my motor oil has an ISO code first digit 14; meaning a maximum of 160 particles per ml. 160X4730=756,800. Now, 23,650,000 MINUS 756,800 EQUALS 22,893,200.
Particles, especially catalytic metal particles like copper, iron and lead increase the rate at which oxidation occurs. Particles also strip the oil of its polar additives, including anti-wear additives, extreme pressure additives, rust inhibitors and dispersants. Also, numerous very small particles in stable suspension can cause the oil's viscosity to increase. Abrasive particles are responsible for much of the wear leading to premature failure of mechanical components. Under sliding conditions, clearance-sized particles enter the oil film between surfaces and cut away material much like a lathe cuts metal. Under rolling contact conditions, particles transfer concentrated load between two surfaces in relative motion, resulting in surface fatigue, pitting, and spalling. Particle-contaminated oil traveling at high velocity can also cause erosive wear.
Now, I have ELIMINATED 22,893,200 [that's almost 23 million](obviously an approximation) of these particles from continuous circulation throughout my engine's life blood system; and you are claiming that no engine has any chance of any longer service life because of results like this? Really?
If there is no need for "super-fine" filtration, please explain how and why these bypass filter manufacturers exist and seem to be thriving; and most of them market products suitable for the automotive market; and too many of them to list boast of US patents:
http://www.kleentek.com/?utm_source=bingads&utm_medium=cpc&st-t=bing_kleentek
http://www.kleenoilusa.com/
http://www.fs2500.com/
http://www.microgreenfilter.com/ is this really a bypass?
http://perfectfiltration.com/
http://www.gulfcoastfilters.com/
http://www.cot.se/en/home.aspx
http://www.ntz-filter.com/Introduction
http://www.puradyn.com/
http://www.triple-rrr.com/
http://marineoiltechnology.com/
http://www.trabold.net/English/
http://www.ecomicrofilters.com/whareclpacs.html
I haven't even included Amsoil or Frantz, which are so well known they need no introduction. I believe every above listed manufacturer claims potential extended engine service life. But David Newton knows better?? I disagree sir.
Cheers.
Dnewton3, I can understand and agree with you about the latest synthetic oils and filters being better than say 10 years ago even, but that does not automatically mean that bypass filtration does not add benefit to an engine. Oils are not 'that' good, and manufacturing techniques/design are still not 'that' good.
I am beginning to appreciate the honest manner in which you jest; I can take a joke, and look forward to the exchange! In that manner, I think it is you who may be surprised at what these studies do and do not prove! Please read on, but be forewarned, my answers are lengthy and wordy. I have been accused many times of having diarrhea of the keyboard; can't imagine where that comes from ...
I, too, have a quality control background; I do statistical process quality control for a living now in the HVAC manufacturing industry. Your experiences and mine are probably similar in terms of understanding data sourcing and analysis I would think.
Additionally, I have previously stated, and will do so again, that I don't think BP filters are worthless. To the contrary, they have a very pragmatic application as a fiscal savings tool. Additionally, in environments that require a hyper-clean fluids, they are paramount to successful operation. However, that does NOT extend to the common use in how they are viewed on this site, as well as the hap-hazard manner in which folks interpret the limited studies that have been done on them. I hereby again state that I am constraining my comments to the automotive applications, and typical use we see here. I'm not speaking to other industrialized applications; that was not my point here. So please do not bring things into the conversation that I neither stated or implied.
If you don't own the SAE papers, then you're grossly misinformed and/or ignorant (not intended as a slam but a description of the lack of info) as to the content of any of them. I do have a copy of two of them, and I'll go ahead an purchase one more. I'm going to exclude the one from 1966; it's nearly 50 years old and cannot hope to offer any relevance.
Before you dismiss my position, I think you should understand how it is that I have come to eschew the two studies I do own copies of. Rather than type it out, I'll quote myself from another post ... this first quote are my statements regarding the GM filter study 88-1825:
Originally Posted By: dnewton3
First of all, we should agree that there are two filters on the typical engine; an air filter and an oil filter. The air filter generally deals with silicate ingestion; the oil filter deals with soot generated from the engine, as well as anything ingested that would pass into the lube system, and wear particles themselves.
We need to understand how a "normal" engine ingests contamination via air filtration. I offer Jim Allen's excellent explanation here: https://bobistheoilguy.com/forums/ubbthreads.php/topics/3229015/5
Depending upon how often you change air filters, you can significantly alter the ingestion rate. Just as with any filter, frequent changes actually REDUCE the efficiency. So I'm going to make some assumptions upon average folks and not anal-retentive BITOG over-achievers ...
Using Jim's data, I'll estimate that approximately .75 oz of dust ingested over perhaps 30k mile air filter change intervals. That is equivalent to about 21 grams of dust.
In regard to the GM filter study, I call into question not the validity of the study itself, as I understand the premise of its intent, but rather the application of the study to real world use of filters in everyday lives of millions of pieces of equipment. I'll go over my contentions one at a time:
1) Contamination loading:
In the GM study, they dumped 50 grams of fine AC dust into the sump every hour, for 8 hours. (Page 2, first paragraph). That is 400 grams of contamination over the 8 hours of testing. They did this to "accelerate" the wear attributed to differing filtration levels. For us to understand how much this relates to the "real world", we have to understand how much dust would enter an engine during normal use, and then figure an estimated mileage duration that would infer, presuming average air filter changes and loading. Using Jim's data, we can use the average of 21 grams of dust every 30k miles. Considering GM induced 400 grams of dust in the entire test that would be roughly equivalent to 19 air filter changes. Multiply that FCI quantity by the miles per change and you can see that the contamination loading was equivalent to 570k miles of typical road use dirt ingestion. Yes - you read that right; the sump in the GM study suffered Five-Hundred-Seventy Thousand miles of contamination loading based upon typical air filter changes. As I already stated, this is somewhat dependent upon your air filter change interval, etc. While we could debate this exposure duration, let us just agree it’s a LOT of contamination represented by a LOT of miles. Whether you think it’s 400k miles, 500k miles, or 600k miles is of no real consequence to me. Most folks NEVER own and operate a vehicle or other piece of equipment this long. This represents a HUGE amount of dust ingestion; more than a lifetime for most folks.
2) Oil sump changes:
In the GM study, they never changed oil for the duration of the test. While they did filter it, they never changed it, relative to each filter used. Each sump lasted 8 hours for each filter trial. Given that the sump endured an approximation of 570k miles of contamination ingestion, the OCI duration equivalent in terms of ingestion loading was also 570k miles. That does NOT mean the other contributors to contamination were equal; there is no reason to believe that soot loading was very high as only 8 hours were run per test. Soot loading is a factor of incomplete combustion byproducts; that is not an issue here because the engine simply didn’t run long relative to the real world OCI. In other words, the engine did not burn 570k miles worth of fuel; it only burned 8 hours of fuel, so the soot loading would have been very low relative to the ingestion of the fine dust. But the "age" of oil in terms of the variable manipulated (fine AC dust loading to affect wear) was prolifically long to say the least. A "typical" person would perhaps OCI every 5k miles, and would have seen 114 oil changes relative to the contaminant loading. To put that in perspective for 8 hours duration, they would have changed oil every 4.2 minutes to represent "normal" OCIs in terms of contamination. But they never changed oil at all. And so the sump loading of contamination was allowed to become extremely prominent to say the least. The overall presence of particulate was WAY more than a typical sump would ever see even in a worst case scenario. Why do we want to understand this? Because, while the filtration was manipulated ABOVE 15um, the net result was that a huge amount of small particulate stayed in the sump for the entire 8 hours! Any particle that was 5um, 7um on up to 10um was able to continually circulate repeatedly with no capture at all! Those particles (and there were certainly a LOT of them according to the data) just floated along indiscriminately and did damage while no filter was able to remove them. Therefore, because they didn’t change oil, they never got rid of the small particles (5-10um) that do a lot of damage. They dumped in 500k miles of dust, and then never addressed particles that are capable of damage below 10um. That 10um size is important and will be discussed further down; see the * … In short, because they never did an OCI for the equivalent of 500k+ miles of dust ingestion, the UOA wear data represents a LOT of metals due to smaller particulate never leaving the system; never at all.
3) Add-pack condition:
In the GM study, because they heavily dosed with dust, thereby creating artificial wear rates over one R-E-A-L-L-Y_L-O-N-G OCI, the additive package was greatly overwhelmed. The anti-agglomerates and detergents were so hopelessly over-run that I cannot really find a way to describe or define how it could be measured. Let it suffice to say there was no hope that the additives would have been able to handle the loading. Referring to the OCI duration in point #2 above, a 570k mile OCI with only oil filter changes isn’t representative of real world add-pack health. Admittedly, silica is not directly controlled by dispersants, but they can alter the ability of the add-pack to function when their concentration is so grossly high. I don’t know of any SAE study or ASTM test that can show us a definitive cut-off point or direct correlation, but I highly suspect the 570k miles of equivalent silica is “over the top” to say the least. I’ll note this as well; because the test was only run for 8 hours, we can exclude soot contribution to the loading of particulate; the engines simply did not run long enough to really produce a significant amount of soot. Eight hours is only one full day’s drive, after all. Overall, this topic is moot in terms of wear contribution. And so, the VAST majority of wear is only attributed to the equivalent of ingestion wear and not hydrocarbon byproducts.
4) Filter efficiency:
In the GM study, all filters were rated at 98% efficiency (a fairly good rate overall) at the desired particulate range as the starting point. They tested eight (8) filters total; four for a diesel engine and four for a gasoline engine. The four diesel filters were rated at 40um, 15um, 8.5um and 7um; all rated at 98% first pass. The gasoline engine filters were rated at 40um, 30um, 25um and 15um, again 98% first pass. They used the 40um filter as a “baseline” for performance. Now, we need to understand that today’s “typical” filter is nowhere nearly that bad in terms of performance. Many filters are available that can be 98% at 25um or maybe even 20 um, some are even 99% at 20um. Therefore, the “baseline” of the “improvement” in wear reduction really isn’t based upon a realistic starting point. We can easily get a decent filter that is 95-99% efficient at 20um from any manner of brands. The use of a 40um filter for a starting point may or may not have been reasonable back in 1988 when the study was posted, but it’s not anywhere reasonable today as most filters are much more efficient than that. So the claim by GM that filtration can reduce wear by “70%” is biased in that they started from such a poor state to begin with. That “70%” wear reduction rate was based upon contrasting the 40um filter to a 15um filter in the gas engine application. They showed a 70% reduction of wear going from the worst to best filter at 98% efficiency. But in today’s world, it would be easy to start at 20um as “baseline”. And frankly, you’d struggle to find a filter that would be so efficient at a significantly smaller size anyway in terms of full-flow performance; I’m not aware of a filter that is commercially widely available that would be 98% at 15um off the shelf.
* Also, they noted that while single pass filtration efficiencies can predict relative wear data shifts, multi-pass filtration can also narrow performance disparity when averaged over the life of the test. And I quote:
“Even though filter (A) was rated at 40 micron, it effectively removed particles down to 10 micron. To do this, recirculation of the oil through the filter was required.” In other words, use your filter and the efficiency increases! Just as Jim’s data shows in air filtration, that same concept applies to oil filtration. The longer they used the 40um filter, the better job it did, and to a point where at 10um, there was a convergence of filter efficiency between all filters tested!!! To quote the study:
Note that concentrations converged above 10 micron for all filters. (page 4, fourth paragraph).
In essence, if you use a 40um filter long enough, it will perform as if it were a 15um filter as the pores close down. And any particulate smaller than the typical pore size after multi-pass, will pass ANY filter media anyway. This is why I state that once a filter is appropriately defined in terms of efficiency and pore size, using a “better” filter really does not show any real-world tangible wear reduction. Here is why this happened, so read VERY CLOSELY and UNDERSTAND the cycle of the test protocol.
- They dump in 50 grams of dust (equivalent to 70k miles of ingestion all at once!), and this is done once every hour
- Wear escalates because the FIRST SEVERAL PASSES of the oil allows a lot of garbage to continue around in circulation and generate wear in the engine
- As the media loads up, REGARDLESS of the starting pore size rating, the filter essentially loads to a point where ALL filters tested see performance converge above 10um
Why is this important to understand? Because the filters with larger pore sizes allow a lot more stuff to circulate in the first few passes, causing a LOT of wear in the first few minutes of each hour’s “ingestion”. But after those first several passes, the filters will all settle to a reasonably similar pore size with good efficiency. The wear spikes at the front end of the contamination load in the test, and then it falls dramatically after a few minutes because the media of ALL filters becomes loaded to a point where 10um pores are about the only thing remaining! The filter was ONLY changed once the dP would approach bypass. Until then, the filter just continued to load up and all filters loaded equally well after the first few minutes.
This is why I state that using a “better” filter really does not reduce wear in a tangible manner for the average garage engine in a typical application. While the first pass efficiency may result in a tiny fractional difference, the multi-pass effect over 5k-15k miles is moot because all the filters essentially load up equally. And because we don’t “spike” dirt into the engine (the air filter stays in place and the soot production is a low constant), there will never be a cause for wear to escalate arbitrarily.
(NOTE: The ONLY time we typically see wear escalate is at the front end of an OCI, and that is because of the removal of the tribochemical barriers by the add-pack, as established and proven in the Ford/Conoco study 2007-01-4133. It has nothing to do with filtration in this regard.)
How would all this relate to the real world? Well – if you’re inclined to “spike” your engine with dirt by arbitrarily removing the air filter for a few weeks and driving through a dusty bean field all day long, then this would roughly be a reasonable equivalent. Your wear would escalate dramatically until your oil filter would capture what your missing air filter did not. And don’t forget to not change oil for while you’re at it!
Here’s what I do like about the GM study: they did show a reasonable correlation between wear data in used oil analysis and wear data as measure by % weight loss concentration. This is actually one part of the study I like and believe has merit, although it is only mentioned in passing. They did both methods, as well as relied upon former studies also linking wear data tracking methods to show that used oil analysis can be reasonably used to track relative wear conditions. They also noted that physical measurement methods are prone to errors; you cannot disassemble an engine multiple times during a test and expect repeatability as thing like bearings and such will be altered by the removal and re-installation. However, changes in weight of components had a reasonable correlation to percent shift in UOA spectral analysis; I agree with this!
And so, I contend that the GM filter study was a lab test that did prove what it set out to prove. It showed a reasonable correlation of wear reduction to filtration pore size at a stated efficiency relative to the first few passes. But that entire test was heavily biased towards accelerated wear to a point where no “normal” equipment would ever be allowed to run. The test bordered on, in my opinion, absurd. I would liken such treatment to abuse or neglect. Some would contend that they did this to “accelerate” the wear to simulate 500k+ miles of use. OK – I might agree with that. But again, they did not also do the things in that simulated 500k miles which ALSO go along with wear control. They didn’t change oil at a reasonable frequency; they didn’t change oil at all! Therefore the wear they induced was ONLY applicable to someone who runs a 500k mile OCI, and only manages the oil filter to a point where the component is changed only when the dP across the media is at 10-20psi (a point at which most any normal filter would already be in constant bypass due to complete media blinding anyway) ….
Here is a quote I agree with, but only because they confine their statement well:
By comparing filter bench test performance with the engine wear data, it becomes apparent that a filter’s single pass efficiency correlates very well with its ability to control abrasive engine wear.” (page 5, paragraph 1)
Why do I agree? Because they state it related in SINGLE PASS scenarios. And this is proven true when you never change oil and also dump a slug of garage into the sump!
But if you change oil with normal frequency, and maintain a reasonable air filter situation, and you allow the oil filter to control contamination via MULTI-pass, you’ll NEVER see this kind of disparity between filters.
Do you see the difference between what they did in their “test” and what the real world does in the garage?
And so I disagree with anyone who says that study has merit in the real world. No one I know of, nor any maintenance program I’m aware of, uses such parameters to run their equipment.
And GM even acknowledged this on page 2, in the last paragraph …
"Used oil analysis from engines in the field will not typically show such a clear correlation since wear metals generated between oil changes will be a much lower concentrations."
In other words, they know that because OCIs were negated AND contamination was grossly overdone in their test, simple routine maintenance will not ever result in such wear rates, therefore the filter disparity will never materialize. So GM went to great effort to correlate UOA wear data with weighed component wear data, and then clearly states that real world usage wear data will never show filter performance differences because wear is just never, ever that bad in normal circumstances.
In short, I agree that the test proved what it set out to prove. What I disagree with is that the study has any valid application to real world situations. And anyone who states such will have to prove to me just how they think 500k mile OCIs with single-pass base-rated at ol-skool 40um filters is applicable to today’s equipment management.
I welcome anyone’s interpretation that would otherwise counter mine for discussion, but again I ask that if you want to convince me I’m wrong, please bring PROOF and show how your position is relevant to REAL WORLD applications, because this study most certainly isn’t. Please be willing to discuss how and why you see merit where I do not. Don’t just revert to a position of “because they said so …” What that outwardly indicates to me is that one has not read, and/or does not understand, the basic principles and limitations of that GM filter study.
Now, I'll address the Cummins BP filter study 71-0813:
In similar fashion, and to try and make things a bit more brief, my objections to the Cummins filter study are paralleled to the GM filter study in that there is no practical application for which they were developed. I'll enumerate in a brief sense and cite the direct info;
page 2 - 1st paragraph: "Measurement of the abrasiveness of particles in the field of samples could not be made. ... differences [exist] in the abrasiveness of the field oil sample contaminants and the contaminants used in the laboratory test oil mixture. ... it is believed any differences would affect only the absolute wear values and not the relative wear with various filtration systems."
What this states is that they cannot find a manner to replicate the actual wear data, and they are implying a relative ratio of filtration in the lab. This is similar to the statement that GM made where they were able to differentiate the filtration effect ONLY because they grossly manipulated the inputs. In the actual field data analysis, they could not determine nor replicate the perceived disparity if filtration effect! In short, while they can show a disparity of performance in the lab, they cannot find a manner to correlate that differential to the actual field data in terms of actual wear. That is a HUGE admission that the lab data may not relate to real world use!
As to the topic of filtration efficiency chosen for the experiment, it's my opinion that they may have been reasonably representative of the times back then (1971) but the filters they chose do NOT represent what is typically available today in terms of full-flow performance. On page 2, paragraph 5, they discuss using a full-flow filter they call "60um" (yes, that's sixty), which has a rating of max efficiency at 95% at 40 um. They do not state it's absolute at 60um, but they do show a reasonable efficiency (95%) at 40um. Now, that is NOT a filter which any of us would have to buy today off the shelf. I can EASILY go find a filter for $6 that is 99% at 20um at any Walmart. This is important because it grossly taints the view of what "normal" wear is associated with. Their baseline filter is not in any way what I consider to be "normal" in terms of off-the-shelf performance for typical automotive applications today, or even in the last two decades.
Additionally, page 2, paragraph 6 talks about he BP filter they chose. It was rated at 3um, but there was no stated efficiency at that size. Also, it is a depth media 750 cu-in system. That is HUGE in terms of total capacity, and has extreme effects that most any filter we'd see on a car cannot replicate. Any typical Amsoil, Frantz, Gulf Coast, FS2500, etc we'd see on a Honda or a F-150 or a Duramax will NEVER be anywhere that large. The basis of their BP element has no practical application; you'd never see anything that enormous on a typical consumer-driven vehicle. Why my objection here? Because they ran the testing to a manner which fully loaded the full flow filter to a dP media differential of 25 PSI! The huge system they used had a FF filter that had no BP relief valve, and so when they paired that heavily loaded FF filter with a giant BP element, they benefited from an overly BP-friendly flow ratio. Typically BP filters see only about 10:1 flow ratio; the FF runs 10 qrts for every 1 qrt through the BP. But by using a FF filer that is essentially plugged off, they allowed that giant 750 cu-in BP element to keep on performing which greatly shifts the flow in terms of what is really seen in a typical vehicle. The filters were NOT mounted on the engine; they were plumbed into a sump system that was separate from the engine and fed the same sump volume! Just so you have a conceptual idea of how big the BP filter media was for this study, at 750 cu-in, it has 65% more volume than a Big-Block-Chevy engine! Yes - that's a LOT of filter media, isn't it? 750 cu-in is more than three gallons of volume! Where would you mount that BP filter on your Accord? In the trunk? I suppose, if you drove a Ram 1500 or Ford PowerStroke, you could mount that behemoth in the bed!
They run two types of tests; one is a wear-rate test and one a wear-out test. In both tests, they essentially have to grossly over-dose the sump to facilitate wear that can be quantified in the allowed duration of testing. Again, just like the GM study, they significantly slam the sump with fine AC dust to induce heavy wear. Page 5, in the wear-rate description they speak to the repeated hourly inducement of dust slurry, to a point where they could not longer measure a shift in wear. Essentially, they dump in the equivalent of 7k miles of contamination in just a few hours. In the wear-out testing, they run the engine until it can no longer hold oil pressure and/or consumed too much lube (an amount they did not define in the text). They then measured weight loss of critical components. Again, they ran 7k miles of simulated ingestion in just 5 hours; the equivalent of running 1420 miles an hour! That is approximately 23x greater than what would be "normal" at 60mph, and they did this at WOT full rated speed and full load. They never operated the engine in a "normal" sense of accelerating and coming to steady cruise state. This will admittedly accelerate the wear of ANY engine when run at WOT and full load! Do any of us run at WOT from the moment we start to the moment we run out of oil pressure?
Page 6, paragraph 2 they discuss the "Test Results" ...
Here they take a similar stance to the GM statement of applicability; "These wear rates seem to be toward the high side based on field experience with the engine tested." They mention two reasons the lab experiment does not replicate real world wear:
1) acknowledgement of the WOT/full load system not being typical of real world use
2) acknowledgement that there was never any shutdown; shutdown would allow contamination to settle out and result is reduced wear at start-up, which field use engines benefit from
Page 10, last paragraph:
"... this evaluation has shown the use of good full-flow filtration, combined with bypass lubricating oil filtration, will result in extension of engine wear life up to two to three times the wear life obtainable with only good full-flow filtration."
Here's my beef with this statement; it does not replicate what is real-world to us today for a few very important reasons:
1) we don't have to worry about a 95% 40um filter being our baseline; we can get MUCH better filtration today for a pittance of cost
2) the BP filter they used was HUGE in terms of total capacity and efficiency, and they had to run wear-out tests for about 40 hours; no normal BP element we'd see on a car/truck for our use can reach such duration or efficiency
3) OCI duration was never a manipulated variable
In regard to the last point, this is my beef with all of you who point to these type studies as your "proof" of concept. There is no study that I'm aware of in the SAE journals (or elsewhere) that specifically uses the OCI duration as the manipulated variable; all these studies use the filtration efficiency as the variable. Therefore, you cannot point to the current set of filter studies as proof that they show any relevance in negating OCI duration; cannot be done! You cannot speak to what does not exist!
Generally, these two studies were grossly manipulated in terms of massively accelerated wear via heavy dosing of contamination that does NOT represent real-world conditions. They contrast the best advantages of BP filtration against a sump that is NOT afforded the variability of OCI manipulation.
We would all agree that what reduces wear is clean oil. It is my contention that two general concepts need to be understood:
a) for any piece of equipment, there will be a level of acceptable contamination that will sustain a desired lifespan
b) for any level of acceptable contamination, there is a means of either filtering or flushing out the contamination to maintain that desired effect
You see, most of you don't understand what you're implying by reading a simple, glorified synopsis in the SAE market place. You don't see what was and was not done in terms of making these studies consumable for ease of production.
I do stand by my statements regarding BP filtration:
- generally a complete waste of time/money for most folks as they will not manage the system via used oil analysis, PCs, visual observations,etc to a sensible end in terms of typical vehicle use
- there is NO PROOF that BP filter systems reduce wear tangibly to a degree that is UNIQUE and could not be reproduced via other means (OCI manipulation)
- BP systems are a fantastic tool to extend your OCIs but ONLY if you manage the overall program with a fiscal presence of mind
- BP systems are likely to "appear" to reduce wear, because no one realizes that they are holding the OCI duration as a constant, rather than the level of total wear as a constant; this is a paradigm shift that folks, even in industry, cannot seem to latch on to
- what I believe and profess is that for "normal" operation (sensible OCIs), BP systems will never reduce wear over the alternatives because of two things; 1) the soot levels will not accumulate to a level of being large enough to produce significant harm and 2) the normal silicate ingestion level during the OCI is not anywhere nearly as grotesque in terms of total volume that is generated in the lab testing
- I do agree that BP systems can hold contamination down to acceptable levels for longer OCIs, whereas the extension of an OCI that has only a FF filter will, at some point, reach a point of degradation that tips the scale to the favor of BP filtration. Each equipment application will be unique in this regard and would need experimentation to determine that tipping point
Please explain to me how you all believe these two studies replicate a reasonable sense of real-world application?
- the GM study dumped 570k miles of junk into the sump and NEVER changed oil, and used a baseline of a 40um filter for contrast; GM admitted their conclusions would never be seen in real world use because filtration disparity would not manifest to any such large differential
- the Cummins study also dumped huge amounts of silica into the sump, used a "60um" filter (absolute) as baseline for contrast, and then used a BP filter element (the size of Texas), while allowing the FF filter to essentially blind off; Cummins admitted the study wear data was only relative and not representative of real world numbers as well
HOW IN CREATION DO ANY OF YOU THINK THESE STUDIES PROVE BP FILTERS DO ANYTHING TANGIBLE IN THE REAL WORLD? I caution each of you to NEVER latch onto a synopsis of a study and claim it relevant until you READ the ENTIRE STUDY! I may be the last man standing in this regard, but I do NOT accept these two studies as having any applicability whatsoever to the concept of BP filtration in today's vehicles.
The key I'm tying to impress is that there is a lack of information regarding how OCIs effect wear contrasted to alternatives. There are studies that show finer filtration does reduce wear, but they are heavily biased via serious manipulation, so much so that they are not applicable to real-world conditions. Therefore, when I state that BP filters don't really reduce wear, I am contrasting that approach to one of a well-managed OCI program. NOWHERE that I know of has any study been done regarding comparing and contrasting these two different approaches. The studies you all claim to be relevant are not because:
a) they do not study alternative methodology
b) they do not represent applicability to actual field conditions
Now, ihatetochangeoil, I believe I have shown how those two studies are NOT what you want them to be; I have completely discredited them in terms of real-world applicability. I cite the specific quotation (pg and paragraph) and analyze how they do not relate to real-world use. If you believe I'm in error, then by all means purchase those two studies and counter my points with the same study data available to all. And, regarding the other four studies you cite, I will say we should negate the one from 1966; probably just too darn old. Pick one more and let's dissect it as well.
Be careful what you choose; it may well not represent what you think it does!
Here’s what I do like about the GM study: they did show a reasonable correlation between wear data in used oil analysis and wear data as measure by % weight loss concentration. This is actually one part of the study I like and believe has merit, although it is only mentioned in passing. They did both methods, as well as relied upon former studies also linking wear data tracking methods to show that used oil analysis can be reasonably used to track relative wear conditions. They also noted that physical measurement methods are prone to errors; you cannot disassemble an engine multiple times during a test and expect repeatability as thing like bearings and such will be altered by the removal and reinstallation. However, changes in weight of components had a reasonable correlation to percent shift in UOA spectral analysis; I agree with this!
In similar fasion, and to try and make things a bit more brief, my objections to the Cummins filter study are paralleled to the GM filter study in that there is no practical application for which they were developed. I'll enumerate in a brief sense and cite the direct info;
As to the topic of filtration efficiency chosen for the experiment, it's my opinion that they may have been reasonably representative of the times back then (1971) but the filters they chose do NOT represent what is typically available today in terms of full-flow performance. On page 2, paragraph 5, they disucss using a full-flow filter they call "60um" (yes, that's sixty), which has a rating of max efficiency at 95% at 40 um. They do not state it's absolute at 60um, but they do show a reasonable efficiency (95%) at 40um. Now, that is NOT a filter which any of us would have to buy today off the shelf. I can EASILY go find a filter for $6 that is 99% at 20um at any Walmart. This is important because it grossly taints the view of what "normal" wear is associated with. Their baseline filter is not in any way what I consider to be "normal" in terms of off-the-shelf performance for typical automotive applications today, or even in the last two decades.
They run two types of tests; one is a wear-rate test and one a wear-out test. In both tests, they essentially have to grossly over-dose the sump to facilitate wear that can be quantified in the allowed duration of testing. Again, just like the GM study, they significantly slam the sump with fine AC dust to induce heavy wear. Page 5, in the wear-rate description they speak to the repeated hourly inducement of dust slurry, to a point where they could not longer measure a shift in wear. Essentially, they dump in the equivalent of 7k miles of contamination in just a few hours. In the wear-out testing, they run the engine until it can no longer hold oil pressure and/or consumed too much lube (an amount they did not define in the text). They then measured weight loss of critical components. Again, they ran 7k miles of simulated ingestion in just 5 hours; the equivilant of running 1420 mile an hour! That is approximately 23x greater than what would be "normal" at 60mph, and they did this at WOT full rated speed and full load. They never operated the engine in a "normal" sense of accelerating and coming to steady cruise state. This will admittedly accelerate the wear of ANY engine when run at WOT and full load! Do any of us run at WOT from the moment we start to the moment we run out of oil pressure?
Here they take a similar stance to the GM statement of applicability; "These wear rates seem to be toward the high side based on field experience with the engine tested." They mention two reasons the lab experiement does not replicate real world wear:
"... this evaluation has shown the use of good full-flow fitlration, combined with bypass lubricating oil filtration, will result in extension of engien wear life up to two to three times the wear life obtainable with only good full-flow filtration."
- what I believe and profess is that for "normal" operation (sensible OCIs), BP systems will never reduce wear over the alternatives because of two things; 1) the soot levels will not accumlate to a level of being large enough to produce significant harm and 2) the normal silicate ingestion level during the OCI is not anywhere nearly as grotesque in terms of total volume that is generated in the lab testing
Thank you Dnewton.
You have a way of explaining things very simply and in a manner even I can understand.
You are an asset to this site and I thank you for your input
Dear DNewton,
You are becoming dear to me. Perhaps I should have been a little more "wordy" myself. The two studies you cite, 88-1825 and 71-0813, are studies that MAY be in the public domain, I'm honestly don't recollect where I got them, but I too, have read them in full, and I don't mind at all your "diarrhea of the keyboard," it's actually kind of like classroom review. I'm familiar with everything you stated; but you have rebutted very little of what I posted.
You've done an excellent job of "debunking" two studies and ignoring my questions. Ho-hum.
I answered truthfully YOUR question of "have I actually read these studies?" by stating that I posted their public synopsizes, but I have not actually read all of the entire studies themselves to delve into the specifics. I don't mind spending some money to actually purchase and read them in entirety, but I'm not made of money either.
YOU, however, did not even address my question of API standard(s) of cleanliness for new motor oil. What is the ASTM or API standard or specification? IS there one? If you can't cite or find it, what is your basis for denying that an oil change is equivalent to throwing sand into your crankcase? I noticed with keen interest that you made no attempt whatsoever to discredit my statement of "new" motor oil registering on ISO 4406 a first digit code of 19, being up to 5000 particles PER ML; or 23,650,000 for a typical five quart system. Are you REALLY going to stand by your claim that bypass filtration has no tangible benefit if we restrict our conversation to the automotive market?
Removal of 23 MILLION wear particles has NO lasting effect on a typical automotive engine? You made no attempt whatsoever to argue or deny my common sense statement that FRICTION generates wear particles, and REMOVAL of 97-99% of these particles has no effect on wear rates? Please.
It is my opinion that NEW oil straight from the can, bottle, or bulk container is a horrible thing to put in your engine. This is commonly known as controlled obsolescence. Rebutt that and we can continue. Yes, I am questioning API service category SN, introduced in 2010, "current data." http://www.oilspecifications.org/articles/api-sn.php
Incidentally, I HAVE contacted the Institute for Petroleum Quality http://www.pqiamerica.com/ and Mr. Tom Glenn told me that he has never before been asked about a specification for cleanliness for new motor oil, and he proceeded to tell me of HIS background and experience, but he admitted to not knowing of such a specification. So, enlighten both of us if you can. Meanwhile, so far, you've done an epic fail of convincing me of anything.
The question to answer sir, is, what is/are the cleanliness specification(s) for new motor oil? Answer this with an API or ASTM specification, which I will purchase, if necessary, to read. If none exists, how is an oil change NOT equivalent to throwing sand in your crankcase?
I just want to say I have never read nor have I referenced these papers you guys are talking about to make an 'informed' decision on a bypass filter system.
DNewton3, you have stated about soot levels and particle levels (contamination) not being high enough to cause any 'significant' engine harm. How do you know this, and what do you mean by 'significant'? I think on the subject of wear rates, it is difficult to objectively put a number on real world differences between standard full flow and BP filters, as in reality, it is a subtle 'instantaneous' difference, but may be a large longterm effect. Example, an engine from 'vehicle X' has an average life of 250,000miles with wear rates gradually increasing through the later years. However, with a bypass filtration setup that engine life 'may' be extended to say 500,000 miles, but wear rates would be much lower and the engine health would be much greater throughout it's service life, and would likely fail because of other problems not commonly experienced in normal OCI and filtering.
Regardless, I am just talking out of my @$$, but I don't care, my bypass filter setup is definitely not going to hurt my engine (unless you have some other evidence that super clean oil is harmful) and it will at the very least save me money on oil and filter purchases.
I will confess I have no detailed understanding of where a sensible level of filtration would be. I don't know what standard of "clean" is necessary for "new" oil. I didn't mean to ignore your questions; I got caught up in debunking the two studies I'm quite familiar with. My apologies. However, I would struggle, in all honesty, to be able to contribute to your specific question; I just don't have data relative to "new oil" particulate loading.
But - I contend I can provide reams of data (over 10,000 used oil analysis form Blackstone, as well as many thousands of others from other sources) that shows what is "normal" in terms of successful operation of all kinds of equipment. And my "normalcy" article on the home page has all the proof you'll need.
Here is what I think you and I could agree on:
1) finer filtration will reduce particulate loading (a no brainer)
2) SAE studies are heavily biased to lab experimentation and generally do not address real world situations (except my reference to 2007-01-4133)
3) SAE archives lack any credible data comparing/contrasting the concept of OCI manipulation and filtration manipulation methodology
4) SAE archives lack any credible data establishing a level of particulate loading level that would show correlation to any desired lifespan
What we can see is that extending OCIs to (what I'll call) "moderate" durations can greatly reduce wear rates, nearly to zero; (SAE Ford/Conoco study 2007-01-4133) and my own data files establish this as indisputable fact. Generally, running a "normal" oil and filter out to 15k miles will reduce wear rates on a factor of 10X! This is because the bulk of the wear happens at the front end of the OCI, and once the tribochemical barrier is re-established, the wear rates drop precipitously. This is well explained in my normalcy article. To contradict this is foolish; too much data supports it to come to any other conclusion. (Please note, it is important to acknowledge that we're talking about healthy engines with good design; not a known sludger or handicapped design; those are excluded for obvious reasons).
Therefore, if simple OCI extension will dramatically drop wear on a factor of 10x, how is it we could credit a bypass filter with reducing wear over that same 15k miles?
Here's my issue with folks pointing towards those "filter studies" (your list) and latching onto them as if they were golden advice from above ...
They were done PRIOR to the revelation that Ford/Conoco submitted in terms of OCI extensions using NORMAL products. All those filter studies predated the 2007 study which clearly shows dropping wear rates are completely normal using "normal" products (standard filters and conventional oil).
Additionally, those filter studies are so grossly biased towards negating OCIs with super-duper sump contamination loading that there is no reasonable expectation whatsoever to think that the "lessons learned" in those studies are applicable to real life. In addition to the two I do own from your list, I also have a very detailed one from Fleetguard (not published in SAE to my knowledge, but it may have sneaked in under a title I'm not aware of). This Fleetguard study is just as ridiculous in terms of practical application as the two others I have. This is the basis of my discounting those I don't own; I have little faith that they reveal anything "new" in terms of real-world data.
In terms of friction reduction, I will again point to that very same Ford/Conoco SAE study; it directly addressed that topic as well as wear rates. In the study, they discovered a dramatic drop in friction after the tribochemical barrier is established. In fact, the study title is thus:
"The Effect of Oil Drain Interval on Valvetrain Friction and Wear". In there they note that as the tribochemical barrier is re-established and matures around 3k miles, the friction drop is 8-16% depending upon rpm. Only when the engine oil thickens due to a vis change will the friction increase. Even out at 7.5k miles the friction drop was 13-22%! (pg7, prgh 1). And so, your assertion that super-fine filtration is the cause of a friction reduction is ill-considered; your implication is incorrect!
The Ford/Conoco study directly proves (by using normal oil and filters) that OCIs even out to 15k miles show a HUGE reduction in wear (several "orders of magnitude" from page 3, prgh 2) and up to 22% friction reduction. The increase in vis will increase friction, but that is NOT the main controlling factor. On page 12, the last three paragraphs indicate conclusions:
"In general, the wear rate and the friction torque observed with the 3000 mile drain oils were much lower than those of the fresh oils and these were maintaned as the oil drain interval was increased. The friction reduction was in the range 8-22%.
The viscosity of the drain oils increased progressively as the drain interval increased from 3000 mile to 15000 miles, but the wear rate of tappet shims and friction torque did not change appreciably indicating the reduction in wear rate and friction is related to changes in oil chemistry with aging.
The composition of surface films formed with aged oil was quite different from those formed with fresh oils ... The much improved wear rate and friction reduction are believed to be due to the formation of the new film."
In short, you're latching onto data from 20-40 years ago, when a study done in 2007 DIRECTLY controverts much of the previously assumed concepts. Wear rates and friction reduction are controlled first and foremost by TRIBOCHEMICAL BARRIERS established after an OCI!
The Ford/Conoco study does state that this information is only valid out to 15k miles; that was their chosen delineation of where to stop. The data indicated that the wear rates were not rising, nor was the friction being altered at 15k miles; they simply chose to stop at that point. They cannot say one way or another WHEN those trends would reverse. Any sensible person would agree that at some point, there will be a reversal of those trends and wear would go up and friction would greatly increase. But we know FOR SURE that it happens at some point beyond 15k miles; how far beyond we do not know because the data does not exist to establish it as of yet in SAE archives.
Therefore, when you speak to wear and friction, and (in error) attribute the desired effects of wear reduction and friction reduction, you are (to be blunt) wrong to attribute those phenomenon to the concept of finer filtration in short-to-moderate OCI durations. I do agree, at some distant point, that bypass filtration would tip the scales in its favor; there is some yet unknown OCI duration where "normal" products would begin a slide of degradation with increased wear and increased friction.
So, conceptually, this is why I repeatedly state that bypass filtration does NOT reduce wear in "normal" applications. In fact, if one accepts 5k mile OCIs as "normal", then extension out to 15k miles would be seen as absurd by some folks, and yet data proves beyond any doubt that a healthy engine will actually benefit from OCI extension, even without the perceived need for bypass filtration!
What I would grant you is that the SAE study I cherish so much never did test that same scenario using a BP element to compare/contrast data. Is it possible that a BP element may have made the wear rates even "better"? On the surface, one may say yes, but I disagree, and here's why ...: (pg 6, last prgh)
"... both the 7500 mile drain and the 150000 mile drain oils showed nearly zero wear rate ..."
I ask you this: just how much better than "near zero" do you expect wear to be?????? Be realistic here; when wear rates are at "near zero" for the vast majority of a 15k mile OCI, then what tangible benefit do you think a BP filter would be????? I suspect it would be nearly improbable to even measure the correlation/causation of such a filter when "near zero" wear is already the norm. The noise of statistical variation would probably mask over any theoretical miniscule contribution you hope the BP might make.
And while some folks may claim that the Ford/Conoco study is just a lab experiement, I offer these two stunning supporting facts:
1) the oils used in the study were taken directly out of taxi fleet cars from Las Vegas, after use out to 15k miles in real world applications, and then tested in the lab to reveal what real world use results can be found; this was not a conjured-up concoction of dust-slurry-laden accelerated wear guesses
2) my 10,000 used oil analysis (taken from thousands of applications from cars, trucks, tractors, generators, etc) also back up this study; there is clear, concise proof that directly echos the exact phenomenon seen in the SAE study; there are multiple examples of this in my data available for all to read on the homepage
What I want you, and others, to understand is that in "short to moderate OCIs" (out to 15k miles) it is NOT filtration that controls wear or friction; it is the tribochemcial barrier! And so, when the wear-rate is "near zero", what I contend is that oil is already "clean enough" and does NOT need to be cleaned further. There exists no proof I can see that making oil "cleaner" would make the wear or friction any "better". And this is why I state that oil is already "clean enough". I cannot tell you anything whatsoever about the quantifiable limits of what "new oil" must meet in terms of cleanliness; I have no data to establish such limits. But I CAN tell you that, whatever limits are currently being met, are "good enough" to establish "near zero" wear rates out to 15k miles!
To be clear, I am NOT stating that filtration is worthless; that is absolutely untrue and you would be misunderstanding me if you take that from my writings. What I am stating is that normal filters already provide sufficient reduction of contamination to a degree that adding "more" (finer) filtration does not result in reduced wear out to 15k miles. Once a FF filter takes out the big chunks of stuff, it is the chemistry of the film-barrier that controls both wear and friction, not a "better" filter. If a "normal" FF filter is capable of supporting "near zero" wear as a supplemental tool to the tribochemical barrier, then what do you hope to achieve by making the filter "better". You CANNOT make something "better" that is, for all intents and purposes, practically non-existent in the first place!
Most assuredly, I would be in complete agreement with you in that, at some point, BP filtration will be able to clean a sump to directly cause an effect. That is obviously past 15k miles, and possibly even further out.
To support my position, let's consider the application of real-world data into another example. Go back and read the normalcy article and pay special attention to the Dmax engine portion where I compare my 2006 to another BITOG member's Dmax. They were nearly identical, used in very similar circumstances, for the same OCI duration. I ran conventional oil and a normal filter; he used 15w40 syn and a BP filter. And yet, at the same OCI examination point, the used oil analysis were completely statistically similar; both were well within one standard deviation sigma node. They were so completely "normal" that there was no practical way to tell one from the other, and had I not labeled them, not one person would be able to know one from the other! That is REAL WORLD data that completely supports both my thousands of used oil analysis, and the SAE 2007-01-4133 study, all of which use real world data and not some trumped-up biased lab experiment.
Because wear is "near zero" out to 15k miles, and the BP element would have ZERO tangible effect in terms of actual statistical delineation, then one can conceivably replicate a "near zero" wear rate repeatedly simply by changing oil!
- if we had a "test" out to 75k miles, we could establish two methodologies; one vehicle would get 15k OCIs five times, whereas the other would use one OCI with BP filtration once
- the effective "near zero" wear rates would be so similar that we'd never be able to tell them apart in terms of data; the normal variance of noise in the UOA would greatly overwhelm what tiny, sub-fractional difference may or may not exist
- therefore, I can attain the very same wear and frictional experience with "normal" products as can you with bypass filtration
- the BP filter could likely sustain a "near zero" wear-rate by keeping the oil clean for that LONG duration, but it is completely reasonable (and proven) to expect that the same result can be experienced simply by changing oil thereby also sustaining that "near zero" effect! The BP filter could sustain near zero LONGER, but it CANNOT improve upon something that is practically non-existent!
- this is why I state you can either flush or filter out contamination to any desired level of resultant wear in terms of "normal" engine operations (again - I exclude the topic of hyper-clean requirements; that's not the topic of this conversation)
This is why I state that for "normal" operations, bypass filtration has no tangible effect in wear reduction. The filter studies from 30-40 years ago are NOT applicable to real world studies, whereas the 2007 study (using actual field drain oils from taxi cabs) shows the chemistry is the number one controlling factor of both wear and friction up to 15k miles (possibly further). And this is why I also state that BP filtration is a FISCAL SAVINGS TOOL and not a wear reduction tool.
I realize this flies in the face of what you want to believe, but that is because you're relying on 30-50 year old filter studies that were biased in super-heavy sump contamination, rather than relying on a recent study that established the TRUE foremost contributor to wear and friction control. And with tens of thousands of used oil analysis to back up that SAE study, I have to say I am VERY CONFIDENT in my position of these points:
a) I don't care what quantifiable level of contamination exists in "new" oil because the market is supplying a product that is capable of "near zero" wear
b) cleaning the commercially available "new" oil to a point of near-clinical purity does not result in any tangible shift in wear or friction reduction because it is NOT filtration that is the main contributor to these criteria at least out to 15k miles
c) because wear can be maintained at "near zero" levels with OCI manipulation, the topic of "less wear" using BP filters is false; I can maintain the exact same level of low wear simply by changing oil frequently enough to control contamination via flushing, rather than filtering
d) because I can maintain the same level of effective wear control via OCIs (versus filtration), it can concluded that bypass filtration is a means of fiscal control; I can control costs to a more effective ROI by using less oil via bypass filter utilization!
In short, I've said this before and I'll say it again:
I don't care about inputs; I care about results. It makes no matter to me whatsoever what any particular oil has in terms of additives and in-bottle contamination, because real world data shows that what the market offers is good enough to make a piece of equipment last nearly forever, if maintained properly.
My position
- uses data from a reasonably current SAE study; that study undeniably establishes the fact that chemistry controls both wear and friction out to 15k miles, not filtration, because when wear-rates are "near zero" it is implausible to hope that it could be any better in real life
- utilizes data from ten-thousand used oil analysis which echos this same phenomenon, and my "normalcy" article clearly illustrates multiple examples of how this "near zero" wear exists in thousands of pieces of equipment in real world use
- my person micro-experiment with my Dmax and that of a fellow member's also echos the claim that syns and bp filters do nothing to alter wear in normal use (even in heavy towing use)
- "near-zero" wear rates are NOT exclusive to bypass filtration; they can be maintained with a managed OCI frequency
- any variation between wear rates of different methods would be so small that it would be impossible to statistically differentiate such minutia; it's a fool's errand to discuss this matter as it cannot be reasonably measured in today's data (I can state this with emphatic truth after trying with all due diligence in my reams of data)
- current "normal" products (FF filters and "new" bottled oil) already provide an environment that support near-zero wear rates out to moderate OCI extensions
- BP filters can only extend what already exists; they cannot improve upon near-perfect data
Your position
- uses info from decades old lab studies
- the study data is heavily biased with unrealistic levels of sump contamination that would NEVER be seen in any sensible manner and are, essentially, conditions of total neglect and abuse
- the lack of any true known level (or established industry limits) of cleanliness in "new" oil does NOT alter the fact that, despite the lack of info, the real-world results indicate that whatever does currently exist in the bottles on shelves today is "good enough" to supply "near zero" wear rates and reduced friction out to 15k miles; i.e. - not knowing the level of contamination in the bottle does not refute the fact that it's clean enough to produce "near zero" wear
- BP filters will improve upon wear rates in all conditions
In short - I disagree with you based upon relevant SAE data, many thousands of used oil analysis I've studied, and my own person experiences.
In a friendly sense (
) I think I've shown that my positional statements are well founded in real world experiences, whereas yours are based upon decades old, unrealistically biased, grossly manipulated, poor methodology. Now, if you see if differently, then please quote your sources, show your data calculations, and explain just where you think it is I'm off in my assessments.
2) SAE studies are heavily biased to lab experimentation and generally do not address real world situations (except my reference to 2007-01-4133) I don't think the taxi cab study is real world either, who runs their cars all day?
What we can see is that extending OCIs to (what I'll call) "moderate" durations can greatly reduce wear rates, nearly to zero; (SAE Ford/Conoco study 2007-01-4133) and my own data files establish this as indisputable fact. Generally, running a "normal" oil and filter out to 15k miles will reduce wear rates on a factor of 10X! This is because the bulk of the wear happens at the front end of the OCI, and once the tribochemical barrier is re-established, the wear rates drop precipitously. Not really what I have ever seen in used oil analysis here, or anywhere for that matter, most used oil analysis show pretty linear wear accumulation over the OCI, out to 15k miles like what you are talking about. This is well explained in my normalcy article. To contradict this is foolish; too much data supports it to come to any other conclusion. (Please note, it is important to acknowledge that we're talking about healthy engines with good design; not a known sludger or handicapped design; those are excluded for obvious reasons).
Therefore, if simple OCI extension will dramatically drop wear on a factor of 10x, how is it we could credit a bypass filter with reducing wear over that same 15k miles? Well, you are rounding down to zero, not really accurate of real world, engines are still wearing out.
They were done PRIOR to the revelation that Ford/Conoco submitted in terms of OCI extensions using NORMAL products. All those filter studies predated the 2007 study which clearly shows dropping wear rates are completely normal using "normal" products (standard filters and conventional oil). I sure hope there is more than one party doing this same study, the same results have to be reproduced by other independent groups. I wouldn't trust Ford, nor Conoco. Not saying any and all of the their data is wrong or fudged, but you also can't take it as golden advice from above.
How did they measure the friction reduction?
So, conceptually, this is why I repeatedly state that bypass filtration does NOT reduce wear in "normal" applications. In fact, if one accepts 5k mile OCIs as "normal", then extension out to 15k miles would be seen as absurd by some folks, and yet data proves beyond any doubt that a healthy engine will actually benefit from OCI extension, even without the perceived need for bypass filtration!Not accurate as a bypass setup would have only 3k miles before the tribochemical barrier is established (according to you) and then smooth sailing after that, however with 15k OCI you have 3k miles repeatedly, that is, if the engine can even allow for 15k OCI.
"... both the 7500 mile drain and the 150000 mile drain oils showed nearly zero wear rate ..." Near zero, they are not even being specific what near zero means. I have never seen a used oil analysis with 'near zero' wear, I just don't know how they can say this. To make a point, 0.0035 and 0.0015 are not zero, one is more than double the other...
- the effective "near zero" wear rates would be so similar that we'd never be able to tell them apart in terms of data; the normal variance of noise in the used oil analysis would greatly overwhelm what tiny, sub-fractional difference may or may not exist
My position
Your position
Again, I am not completely disagreeing with you, nor agreeing with you, I am just pointing out some potential errors. I just can't agree that super fine filtration does not reduce wear from an all ready "near zero" wear rate. Erosional wear, not frictional metal on metal.
Well, zpinch, I can accept that you disagree with me.
Clearly, I've articuably discredited the two filter studies for what they are and are not, and obviously I've got tons of data to show how the wear rates are and are not effected by filtration in used oil analysis data. My used oil analysis data includes over 10,000 used oil analysis, with lots of that also coming from engines with BP systems in use. I have the ability to compare and contrast data from all kinds of sources using all kinds of filtration systems and lube choices. There's an SAE study that is time-relevant (only 8 years old now) that shows how a chemical barrier affects the topic; and it echos the data from my study with overwhelming correlation.
It's fine that you disagree. I just ask upon what evidence do you base this objection of yours? Nothing wrong with disagreeing with me, but based on what; a hunch? You say I may have "potential errors" imbedded in my logic? Please take all the time you need to explain them, because I don't see any validity in your concerns.
You don't think taxi cab is "real world", versus the grossly overloaded GM and Cummins studies????? Taxi cabs represent potentially a worst case of real world, but at least it's was done in the context of being performed in the (wait for it ...... ) REAL WORLD! In the GM study, they dumped the equivilant of 570k miles of dust into a sump in just 8 hours. In the Ford/Conoco study, they actually operated a fleet of taxis using normal everyday products (lubes and filters) in real cars (CrownVics) with actual drivers (real people) for what could be considered a worst case condition (heat of Las Vegas). I find it ironic that you would question such a methodology, when just about 99% of the BITOG membership here seems to think that their own personal use is "severe" duty as described by an owner's manual, but then you'd question the ACTUAL APPLICATION by Ford/Conoco of operating their test fleet in just such a condition. I - OTOH - think they did EXACTLY what we'd want them to do. They tested the worst conditions that the REAL WORLD is going to offer. Any disparity that may arise is likely to come from such operation. And, conversely, it is reasonable to preusme that any use that is LESS THAN such conditions, would easily exhibit even less wear! I don't understand you're objection here
; you prefer stupidly, overtly manipulated data from the GM study over the Ford study from the real mean streets of Las Vegas? Your objection was thus:
"I don't think the taxi cab study is real world either, who runs their cars all day?"
So you think that the study was not real world because people don't run their vehicles "all day". That's absurd; while I agree that some folks do not do so, there are LOTs and LOTs of vehicles that do run all day (taxis, police cars, delivery vehicles, OTR tractor trailers, generators, construction and mining equipment, etc, etc). By the way, in my tens of thousands of used oil analysis, I do have data from just such use so I have great data to back up this observation! You and I may not run our cars all day, but there are scores and scores of applications that do this as a means of daily operation, and for you to distrust the study based upon this, is, well, ridiculous.
Have you read my normalcy article? There is CLEAR, UNDISPUTABLE evidence of how used oil analysis track wear. I never said wear was at pure zero, nor did the SAE study. It is "near zero" in terms of a wear rate. Until you come up with 10,000+ used oil analysis, and do statistical analysis for a living, and have operated a PM maintenance program for years, I'm going to have to disagree with your assessments.
You say you don't trust Ford or Conoco? Based upon what? Have you purchased and read the study? Have you purchased and read the GM or Cummins study? Do you even understand the process in which these studies are done and submitted to the SAE? Please expound upon your distrust in Ford and Conoco, but you trust what other source?
If you don't know how Ford/Conoco measured friction, then clearly you have not read the study ... It is clearly described how it was achieved. They probably put over 600 words into a lengthy paragraph directly describing how the torque was measured and their rationale in doing so. They used a torsional transducer ("inline torque meter") in the test rig attached to the camshaft as I recall. They did not, however, post a picture of the ISO calibration certificate with public-notary citation; I suppose you'll now question the validity of the torque system as well?
As for the "near zero" topic, all one has to do is read the study, as they have data fields and visual graphs that together CLEARLY indicate what was experienced in the study. Once again - READ the study. I quoted the words "near zero" directly from the study text because that is the term they used; I did this so that my interpretation would not influence the outlook and only directly reflect their viewpoint!
Additionally, if you'd read the "normalcy" article, you'll see that wear in terms of Fe is typically LESS than 1ppm/1k miles after the TCB is established. This will alway vary a bit from engine to engine, but the relative shift is measured in TENTHS of ONE PPM for many applications! Given that the sigma variance is often greater than that, you're plain silly if you think your point about doubling a wear rate is either perceptible or important. And as much as Fe will track with miles, there are other metals to track as well. Those often have wear rates well less than one-PPM. We're talking 0.x here (zero.variable). Is it really your contention that a BP filter is going to reduce wear that small? Even if it did, it would be beneath a number so freakin' low that you would struggle to discern it! I know so; I've tried to find the correlation in used oil analysis data, and cannot do so despite significant efforts on my part in tons of data! It seems to me you are confusing total wear with wear rates; a rookie mistake. Neither I, nor the Ford study, claimed no wear was present. It is a matter of near-zero wear rates AFTER the TCB is established. The wear is so incredibly low that it is inside normal variance. To imply your example of .0035 and .0015 is of value is foolish; it has no relative effect in terms of the topic.
I realize it's rude to call you a fool, and for that I offer a heartfelt and pulic apology; I am not trying to deride you personally as a human being. But you CLEARLY have ZERO idea of what you're implying if you think you're interpretation is going to trump my decades of tribology experience and statistical process training and applications. I'm not trying to be cruel or taunt you, but when you make such implications, you're obviously not understanding the concept of standard deviation and minutia noise in data streams.
Are there example of engines that wear out? Sure there are! But can you provide proof that:
1) negligence was not a contributing factor?
2) BP filtration would have otherwise saved the vehicle from destruction?
There are also many examples of vehicles that go over one-million (1,000,000) miles on just "normal" products with "normal" OCIs!
My point is that for any example you would come up with that implies a worn-out engine, I can find an example of extreme service using normal maintenance. Please don't rush to the internet thinking you're going to trump me here; I assure you I can support my side with as many examples as you can find.
Keep in mind here that my comments are predicated on healthy equipment, and in the context of systems not requiring hyper-pure conditions. I'm talking to real vehicles in real operation. And when those are operated as such, keeping an OCI of moderate duration can return a wear rate so low that you'd struggle to wear it out. You'd never be able to prove with any credible data that a BP filter would appreciably alter the life span. I know; I tried to find that delineation! When I first started this line of study many years ago, I was not out to prove my opinion right or wrong. Rather, I was open-minded and wanted the data to talk to me, and reveal any potential differential that would either justify or discredit choices based upon ROI. I didn't go in with an agenda; I went in not really caring one way or another. All I wanted was to make a reasonable decision on how to operate my vehicles for good ROI. It is the resulting actual data (not hypothetical rhetoric and baised studies) that helped me come to my position today. If the data would point to the other direction, I'd just as fervently defend that mantra. But alas, it does not do so. I am merely an annoying megaphone that resounds real data analysis, not emotional desire. I will not attest to conditions that do not exist. Bypass filters do nothing tangible in terms of wear reduction that would be UNIQUE in operation over well managed alternatives. They DO provide excellent ROI if you use them with both the benefits and limitations in mind. I am more than open to any data (real world, credible data) that would support changing my mind; after all, it's in my best interest to make the most efficient choices to protect my investments! But as of yet, your objections are not well reasoned, nor backed up by any lab study or field data. My position, OTOH, has a three-pronged forked trident to spear you with reality; the SAE study, the field study of 10,000 applications, and my own personal used oil analysis all are in agreement. Three different sources come to the same conclusion. What do you have to usurp that?
You are more than welcome to disagree with me. You're free to believe as you wish. And I do apologize for being blunt; I don't mean to offend you personally.
Okay, DNewton, I am not disagreeing with you per say, I was merely pointing out potential problems with the Ford/Conoco study, I still don't think taxi cab service is severe. Everyday in town, short tripping is severe.
Don't say I reference the GM filter study, I already said I have never read, nor used ANY info/summaries from said paper... I don't trust papers by vehicle manufacturers, I don't fully trust any large corporation for this kind of information... however, that doesn't mean I think it's wrong.
I am on the fence right now as far as my opinion, yes, you have brought some excellent info here, but I, similar to you, like to know the truth.
The main reason I purchased the bypass filter setup was not for the perceived reduction in wear, but as a ROI, like you say, a fiscal saving tool.
I have to go back to work now, so I had to keep this short, but can you share the 10,000 used oil analysis with me? Are they indexed in anyway within a program that can be easily retrieved?
Thanks.
Much of the UOA data is in my "normalcy" article. You can see all the distribution analysis there. The raw data is at work on my computer Minitab program. It's not something I share out; I got much of it from Blackstone and I'm under agreement not to distribute. The rest of it is stuff I gathered from other websites and my years at Ford.
Have a great weekend!
Yeah, well I have a whole swath of data indisputably showing bypass filters reduce friction 100x over non bypass setup...
Not really.
Just curious, what is your opinion on Amsoil signature series oils and what oil would YOU use if you had a dual remote bypass filter setup?
I don't see how one can conclude from your normalcy article that BP filters don't reduce wear, there is no data pertaining to BP filter wear. Did I miss something?
The normalcy article shows the concept of "normalcy", and has several examples of the "near zero" wear. As I said, I am under a gentlemen's agreement to not share the raw data openly.
My used oil analysis are all in a Minitab database, and I can toggle the tables for systems that either do or do not have BP. I can tell you with certainty, under the conditions I previously stated, there is no statistically significant difference. Any difference that a BP filter might make is so incredibly small that it cannot be defined inside the normal variance of wear. And when wear is "near zero" with normal products (as proved by the SAE study), it's just plain impossible to claim things could be "better" in terms of real application.
In the normalcy article, the Dmax examples have two trucks (mine and another member here). Did you not read that part? He ran 15w40 syn with BP filtration and I ran conventional 10w30 with normal FF filter. Our UOA results were practically identical over the same 6.5k mile OCI, under conditions so similar it's uncanny. Both those used oil analysis were completely in line with "normal" wear variance in macro data. You say you don't see any proof of my claim, but it's right there in print, right in front of you! Did you just gloss over it and not actually not read it???
Look - I've clearly laid out why those filter studies are pretty much worthless in terms of real world application. I've showed great correlation between the Ford/Conoco study, market-wide macro data, and my personal used oil analysis, all of which are based upon REAL WORLD DATA and not hypothetical, grotesque manipulation.
At this point, if you're not convinced, you'll not ever be.
Fine by me. I do wish you the best in your endeavors; have a great weekend.
Dear DNewton,
You are becoming dear to me. Last couple days have been pretty rough personally. My brother was taken by ambulance from work to hospital with breathing problems. He's going to be OK, but please understand I've had more pressing matters in my life than responding to you on BITOG.
I sometimes do vendor audits and sometimes drive several hundred miles a day. Not every day, but sometimes. Restricting our conversation to the automotive world, I thank you for your patience with me and non-stop data. Right now, I don't know that I completely agree with you, (I need to read some studies myself), BUT, I can absolutely assure you that I WOULD drive 500 miles to shake your hand. I appreciate and respect you patiently stating your data.
The Bible says to "correct a wise man, and he will love you for it." I'm not sure I'd call myself a "wise man," but I would take offense to someone calling me a fool. I AM a "newbie" to BITOG, and I have found this: http://www.testoil.com/pdf/tlt_filter debris analysis article_2-08.pdf The US Air Force and February 2008 Tribology & Lubrication Technology is certainly current data.
After visiting the website to "Test oil," they state that they do not service private individuals in the consumer sector and recommend Dyson Oil Analysis http://www.dysonanalysis.com/dyson_analysis/welcome.html
I emailed Dyson, and he RESPONDED to me on a SATURDAY morning. I will be sending him a sample for analysis this next week. My question to Mr. Dyson, that he said he could answer with oil analysis, filter debris analysis not necessary, IS: Am I preserving my engine with bypass filtration, or ruining it by over running the oil?
I have been sending oil samples in to "Oil Analyzers," which I have discovered is a "division" of Amsoil, and I have about 12-15 reports on the 3 vehicles I own, sufficient to see that their "comments" are plastic and canned. I have SEVERAL reports stating that "Boron is slightly low for this lubricant," and, researching "Boron as an additive in motor oil," I found this patented product: http://www.altboron.com/
I have installed this in addition to bypass filtration and have no idea if I'm getting any better measurable engine protection or not. I also installed a nanofiber air filter, and my silicon counts went from almost a thousand to under 25; on all three vehicles. Then I acquired a Puradyn PFT-8 filter without cost: http://processfiltrationproducts.com/PuraDynHomePage.html
This filter has 5 US Patents; one of them is for timed-release additives to replenish your oil. I will very shortly be running TWO bypass filters just simply because I CAN. I will continue UOA. Will my engine last any longer? Well, I can get T-boned by an old lady tomorrow. Time will tell.
Thanks for your patience putting up with me. Hope you also have a great weekend.
Well, I am not going to change my opinion on bypass wear reduction based on one example, by you, and one UOA. You should know that you need UOA trending to make an argument either way. Or did I miss something in the article, was this more than one UOA? Please correct me if I'm wrong.
ihatetochange oil -
1) hope your brother is doing better; stay focused on family first
2) please keep the RSP out of threads; against our site policy
zpinch-
Yes, I am fully aware of how data analysis works. Apparently the ENTIRE CONCEPT of "normalcy" in terms of macro and micro data escapes you. Either you read the article and don't understand it, or you didn't read it. There is no other sane and polite way for me to interpret your statements. Yes - you missed something in the article; you missed the whole point from beginning to end.
Allow me to quote myself from the article:
"However, using macro-analysis, we can state that if two separate samples are both within standard deviation, the separate conditions and products did not manifest into uniquely different results. When viewed within an engine family, if engine A is compared and contrasted to engine B, and those two engines used different lubes but resulted in similar wear metal counts and rates, then we can conclude that neither oil was “better” than the other. And when the results are within one standard deviation, the proof is conclusive that neither product had an advantage over the other. Essentially under these conditions, we cannot say that either choice is “better”, but we can say neither is “better”.
You see, in respect to this conversation we're having, I never said that either BP or OCIs were "better". What I am stating is that neither has proven to distinguish itself as different statistically. Therefore, the ONLY rational conclusion we can reach is that neither is better than the other. And my Dmax UOA exmaples prove this with macro analysis! It is there if you're willing to understand how to see it.
To the both of you ...
Perhaps it would be best if I stated this a different way. Previously, I've tried to constrain my topic to the specifics that would interest this site. Guys - I'm not talking about filtration for aircraft, although I am a fan of FDA, but it's not cost effective yet for garage applications. I'm talking about real world applications with true statistical proof (or the lack thereof) based upon used oil analysis.
Any manner of filtration is better than none; that is true. Using "better" filtration is a good thing over the choice of lesser filtration in terms of reducing particulate; also true.
But what you seem to fail to grasp is that there is a law of diminishing returns here. Some amount of filtration is VERY important to a typical engine. However hyper-pure filtration does not show a statistically significant advantage over the alternative of managed OCIs of moderate duration. At some point, the effect of finer filtration in terms of wear control goes below the noise of operation that is otherwise controlled by the TCB. In fact, even with FF filtration, it's nearly impossible to delineate where wear is affected in terms of "better" filters; generally cannot be done.
I never said BP filtration cannot reduce wear. I said that it cannot do this as a UNIQUE trait over alternatives. Therefore, this is a tool for fiscal savings. The effect can be found via mutliple methods, therefore it's not the controlling reason to use BP filtration.
The infamous filter studies are essentially worthless because they do not represent real world applications. The real world application of lube/filters in the Ford/Conoco study is VERY accurate, and is echoed in tens of thousands of used oil analysis from field service all over North America (the preponderance of my data comes from NA). My own UOA experiences echo the same effect. That represents three different sources that come to the same conclusion. How does that not convince you?
You guys keep grasping at straws to try to hang onto a concept that is, IMO, flawed. It presumes that BP filtration is the only way to get longevity, but that is simply not true. Go back and re-read my statements. I said there are TWO roads to the SAME destination; you can either filter out or flush out contamination. Therefore, to imply that only BP filters will give an exclusive result of longevity is completely false; that can be achieved by other means.
Rational Thought Quiz ...
Q1: can engine longevity be positively affected by using superior filtration? Yes.
Q2: can engine longevity be positively affected by managing OCI durations? Yes.
Q3: if Q1 and Q2 can afford the same net effect, is the effect unique? No.
Q4: if Q1 and Q2 can afford the same net effect, what delineates the choice of one over another? Cost of application.
Rational Thought Statement ...
Because Q1 and Q2 offer the same result, they cannot be logically separated due to performance, therefore the correct decision is one of fiscal ROI.
Now - to avoid the uncomfortable sense of animosity, I do want to assure you I see this as a friendly joust of minds and not personal attacks. In that mindset, I offer this; a sign hangs in my offices that reads:
I can explain it to you, but I cannot understand it for you!
