Yep, and this is one reason why UOAs need to be tracked and used as a tool.
Drawing conclusions with a 'single' UOA is all but meaningless, unless there is imminent doom pending.
The benefit of the bypass filter is to remove soot, sludge, insolubles.....
There really isn't much wear in an engine without issues.
The soot/insolubles is one issue that can ONLY be addressed with the bypass filter. This issue is now greatly exaggerated due to longer oil change intervals, emissions control, more stress on the engine, and consumers that do not know how to use a dipstick.
We already use a full flow filter. But, we almost NEVER question it in the UOA section. How accurrate is ANY UOA?
Since we don't worry about the full flow, make an effort not to worry about the bypass filter. It's there, it will remove some wear, it should remove all smaller contaminents hopefully reducing abrasive wear,..... and as long at it doesn't become an issue, use it and track UOAs.
