- Joined
- Jun 3, 2021
- Messages
- 856
Say you have two oils, one blend and one full syn, both are 5W-30 SP gasoline engine oils.
The ambient temp is below 5 degrees F. Cold start in the morning. Both of these oils are within the temp range for their viscosity, but does the full synthetic circulate through the oil galleries and up into the heads quicker than the blend can upon startup? Even though the viscosity rating is the same, does the synthetic have any advantage here due to it's presumed lower wax content, or no?
