Hello,
I changed a bunch of front end parts (Rav 4 2003, 2.0L 4x4 automatic); including brake dust shields, bearings, hubs, rotors, brakes, ball joints, as well as outer tie rods.
I tried to stick to the original alignment as best as I could when installing the tie rod.
I did a DIY alignment using the string method.
On the left measured exactly:
rear wheel both sides of rim 2 inches (reference point for front)
front wheel both sides of rim 1.5 inches
On the right measured exactly:
front wheel both sides of rim 2 inches
The steering wheel is straight. Steering wheel doesn't vibrate. Drives in a straight line. Doesn't squeak.
One thing I did noticed is that the brakes kind of grind a little when turning and some random noise that comes and goes.
I'm not sure if this is the new brake dust shield that is catching the rotor a little bit.
Anyways, should I still do an alignment or am I fairly safe with this configuration?
Thank you
Thank you
