Divorcing Mobil 1
Just a guess here, but you lack the basic ability to use the search function here.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2233731
Put the little pointer thingy over that link and click on it. Maybe I should tell you its the newest koolaid link. You seem to be a keep the forum guys happy and use M1 at any cost kinda fellas.
Look in the comments of elevated wear.
Then come back with why so many fans of that oil say deal with it, run it a,few OCIs, dont worry about the extea noise, it dont cause wear, ignore the UOA that confirms you believe that noise may be wearing the engine, dont worry about that quart you lost after 3,000 miles, superior oils have these characteristics, the guys online told me so. Now that is what I call trolling.
So use the search function here and read all the my car started drinking oil, makes more noise, shows more wear on UOA threads right here when people try a fill of it. Then look at the rediculous excuses people make to try and convince people to keep filling the motor with it. It is almost comical.
Doug is too polite to call you on it but that isn't going to stop me here. YOU obviously failed with the search function.
In case you missed it: http://www.bobistheoilguy.com/engine-oil-analysis/
Was written by the same guy who you just openly flamed and said can't use the search function. I'll go out on a limb and bet that Doug has more oil analysis experience in the last 30 minutes than you'll accrue in your lifetime.
I'd also argue he has more experience with lubricants in general than the collective of everybody else in this thread, covering tens of millions of Km's of real world testing working WITH OEM's AND various lubricant manufacturers INCLUDING Castrol(BP), SOPUS and ExxonMobil.
You've just done the most epic troll of all. You called out a guy with more experience, more expertise and more cred than you will EVER have on this board even if you are here the next 30 bloody years. Oh, and on top of the extensive experience I already mentioned, Doug is a recognized expert in the field of OTR truck maintenance and his publications are nationally recognized in Australia. I know, because I have one of his bloody books!
You've just done the BITOG equivalent of telling Sabine Schmitz that she doesn't know anything about race cars and she needs to use the search function while the sum of your experience in that realm is E-brake sliding your mom's minivan in a Best Buy parking lot.
Congratulations!
I must say this is the funniest thing I have read in a while. I will tell you this. Your oil god you bow to has not run it in a E-TEC II motor where it showed instant clatter and rough idle and poor fully warmed up performance. I have. Would you use that oil again, no matter the brand? Would you run it 30,000 miles because someone online says its normal for a superior oil to exhibit such traits? Heck no. Then when people come here and post [censored] man, yall said this iis the oil the gods use, why is my car so noisy now, drink the oil and run rough. Then the fans come in with run it for 20,000-30,000 miles. Yeah right. Somehow it will smooth out after 30,000 miles. Say what? All that tells me is hey man, let the sludge build up so it can dampen the noise. No way 30,000 miles of a noisy oil will magicaly get more quiet as you use it.
The real trolls are the ones handing out faulty advice to keep filling the motor with it. That is some seriously flawed advice. Also observe I never tell anyone to use my brand because the high iron in a UOA is normal in superior oil, the consumtion is more than normal over your old fill and the noise will become normal to you over time. I have only said use what works best in your application. If M1 works fine for you with extra noise and consumption then good for you. Not for me. (I am talking about me, not you)
Just get it through your head. I will bow, I will not convert. My Harley told me it likes VR1 best, so I use it. The Primary and trans told me to use Formula+. so I use that. CHM runs better in the car than M1 does, so I use it. It will never go in the truck. I wont risk the wasted money on it from hearing it in similar trucks that are used for working and not to go to starbucks for a half caf no milk latte as the heaviest load it will haul.
Some people prefer personal experience for the choices they make over what a fan club says on the internet. Nothing wrong with that. It is obvious the OP has an issue with the performance of M1, the fan boys say no way, its the best ever, dont use anything else it will hurt my (your) feelings. Who cares, its his truck, more than likely it will run better on something else.
FWIW, we had a D-TEC engine (same as the E-TEC) in a 2001 Daewoo Leganza with under 100,000 miles on it and even with regular maintenance (oil changes in less than 5,000 miles, sometimes with synthetic) the rods started knocking horribly before we eventually unloaded it for a fraction of what we paid. I think those engines are just pretty garbage, IMO.
I've never noticed a difference in engine noise/vibrations/performance between oils in any engine I've ever maintained.
Originally Posted By: dave1251
I currently am using QS. I can not tell any difference from PU. Now I have that out of my system we can get back on topic to M-1. I feel cleaner now after defending M-1.
Now, compare that to Formula Shell and see how it goes, just to reassure yourself.
As for me, I've got enough Defy sitting for the F-150 to keep me going for a couple years at the very least.
Nothing of substance has been produced by the M-1 bashers. To the OP use what is on sale. I do and my engines run fine pass emissions and have higher than advertised miles per gallon fuel efficiency.
Sounds reasonable. Guess there will not be a divorce cause Walmart has M1 on rollback!
So.... more useless blather and opinion? Bravo. That's about the calibre of reply I expected.
Keep beating that dead horse big guy. This thread is in dire need of a mercy lock.
Congratulations!
He even posted it on youtube:
Congratulations!
Did you just say an OHC motor rod knocked? As in push rod? I never heard anyone call a knock in a OHC motor a rod knock.
I bet if you would not have ran M1 in it, it would have been fine. I doubt mine would have lasted this long running that oil in it. FWIW I had that motor in another car and it got destroyed in a crash. It ran so well on GTX for 200,000 miles with nothing but oil and spark plug changes on the motor, I bought another one. Same story. Lasting a loooong time on GTX. Same plan. Plugs and the oil every 7500 miles. I never heard of someone dumping a car or motor because they ran the wrong oil, but to each their own.
Edit. When I did the last timing belt on it I changed the valve cover gasket from a tiny weep around one of the plugs. Inside looked great, but that was done long before I knew such M1 fan clubs exsistd. Shoulda taken pics, but even then I would be called a liar. No way anyother oil than M1 has a motor look that clean on part syn oil for 7500 mile OCIs.
The fans are always right lmao.
I know it's probably unrelated but I did have an engine seize up with the vaunted M1 0w40 in it.
VW 2.0T in my Audi.
Where is the additional wear?
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Iron_in_Used_Motor_Oil_Analysis.aspx
Read the long non answer answer. They say something like if you do not drive like a grandma and do not work the vehicle hard the extra wear numbers are nothing to worry about. Then blabber about things the person did not ask about. Pretty much like the non response replies here why the fans4life club members advise people to keep filling the motor with it when they experience the extra noise, consumption and extra iron in the UOA. Sounds like a plan for someone who plans on not owning a vehicle very long. Like the guy with a rod knocking DOHC motor. Yup, he IS the guy I will listen to.
Originally Posted By: GM4LIFE
Oil analysis for one. I compared Mobil 1 to Amsoil in that way. Amsoil can go much farther between oil changes over Mobil 1 and protects the engine better while you go the further distance. Better wear protection with Amsoil.
While Mobil 1 is good oil, Amsoil is excellent. Research the two. There have been a lot of Mobil 1 complaints and rumors of ingredient changes. Amsoil seems to be the gold standard of motor oil these days.
OP said that they wanted to do a 5K oci. It's kind of hard to see a benefit to Amsoil in that situation.
Just another indication that you really have ZERO knowledge about engines. He's talking about a connecting rod! That's what rod knock is!
Yeah, like we should all be listening to the guy who doesn't know what a connecting rod is right?
Just all around win coming from you in this thread. First you slag a product and then swear up and down you aren't slagging it.... while still slagging it. Then you call the only expert in the thread an idiot and then post what was intended to be a knock at another member which only served to illustrate your complete ignorance on the topic of engines. This is an epic saga.
*deleted irrelevant derp*
This is a connecting rod:
It is what connects the piston to the crankshaft. When the rod bearings wear, you end up with rod knock.
But hey, just because you didn't know what a connecting rod was doesn't mean you weren't justified in ripping on Doug Hillary right?
No, you assume M1 does not cause extra wear proven in UOA, you assume it does not cause any extra noise any engine, you assume it does not consume in motors that never did before. So I will assume he meant push rod. If it works for you, it for darn sure will work for me.
I suggest we stop feeding. He's not exploding. He's just growing bigger.
Well, I did suggest a mercy lock earlier, LOL
