So I'm working on a friend's Explorer and I recall installing a new thermostat and gasket last summer, the old one had green sludge on it. I'm doing some repair work and PM on it and I'm going to swap the old green out with G-05 and I want to clean up whatever is in the cooling system. My plan was to use dishwasher detergent(I'll be using "enviromentally safe" detergent) for the first chemical treatment and the tried and true citric acid flush for the second run and flushina via Prestone flush tee for the last steps. This is overkill or should I worry about the water pump seal going out?
