Car is 2003 !echo!; 5 speed manual. OM says 4 pints for the manual gearbox, amsoil product lookup says 4.1 pints. In the past, probably 4 times, I have had the gear fluid replaced and have always handed them (dealer) 2 qts of Redline and no one has said anything.
Last week I drop the car off to have the driver's side axle seal replaced at an indy shop and give them 2 qts redline for refill. I get the car back and they indicate (3) quarts were added; they added another qt of 75W-90 syn. I ask the head there and he said they used the fill hole for filling and had removed the "level hole" to get the proper level.
One whole quart discrepancy? 2 pints? No need to explain to BITOG'rs my uneasiness at this point. What could explain this?
(the discrepancy, not the uneasiness.)
Is there much to worry about? I suspect maybe across the entire gearbox there might be 3/4" extra depth of fluid?
Thanks.
-T
Thanks.
-T
