I really doubt if you'll ever see boiling problems from the lowered boiling point of brake fluid that has absorbed some water in a street car. The components just don't get hot enough. A car that sees track use is a different case for sure.quote:
Originally posted by labman:
Antifreeze, engine oil, etc. actually contact the parts that most commonly fail in those systems. Most brake problems come from poorly maintained hardware or corroded pistons. Most of the corrosion of the pistons comes in the narrow band near the seal, mostly outside the seal, or at least deep in a narrow annular space likely not touched by flushes. You flushers' uncritical acceptance and fanatical insistence of it obscure real problems and reduce credibility about other real world problems. If ''experts'' insist on replacing brake fluid when not doing it seldom creates problems, why trust anything else they say?quote:
Originally posted by JDP:
Based on the logic used here against flushing and changing brake fluid, the only time a change of antifreeze is needed is when a rad or heater core is replaced due to corosion/pin holes or the water pump seal leaks. Change the engine, transmission and axle oils only at rebuild time and UOA is a waste of money in trying to prevent the "unlikely" snip...
JD
There is a large body of data showing problems with not changing antifreeze and engine oil in a timely manner. The reports of problems from old brake fluid are so few compared to the millions of cars with old brake fluid as to suggest that in many cases, something else may be involved. Many of the arguments I read here suggest wide ignorance of brake systems.
Wet DOT 3 brake fluid has a boiling point of 287 degrees F. That isn't far below the heat distortion temperature of aluminum or what it would take to degrade other components. I am sure the pistons get hotter than the brake fluid as they transfer the heat to the fluid. We need to differentiate between problems and bogeymen. No Chicken Little, the sky won't fall if you don't change your brake fluid.
I'd be more worried about possible internal corrosion from the old fluid. In 30+ years of working on vehicles though I've yet to see it be an issue...
