Originally Posted By: coolbird101
sell him your used synthetic for a dollar a quart, geez your neighbor wont get off 20.00 for an oil change that only needs doing twice a year, 20.00 wont even buy him a half tank of gas.
If he is not spending too much time stuck in traffic, then extending the OCI to 5K miles should be considered. The OEM oil filter might be good for 10K miles, but DYOR by checking on the Castrol or Liqui Moly oil finder guides and the Hyundai German web site to see what the OCI limit is in the EU, as that will let you know how long the OEM oil filter lasts, as it might be possible to be alternate oil only changes with a good filter.
This is the German info, but not sure if the engine is correct:
Engine THETA 2.0
Capacity : Capacity 4,1 liter
· Use : Normal
· Intervals : Change 15000 km (9300 miles) / 12 months
Top Tec 4200 5W-30
Top Tec 4600 5W-30
Longtime High Tech 5W-30
· Use : Severe
· Intervals : Change 7500 km / 6 months
The oils listed are not ultra expensive full synthetics but HC or part synthetics.
I would say the cheapest OCI would be alternate oil only changes at 5K miles and full service at 10K miles with an OEM filter, but do check that it is the same filter as is used in the EU, otherwise use a Mobil 1 or Amsoil extended life filter.
