Originally Posted By: Pablo
Originally Posted By: tripleM
cause u get a fool who so often interject with 'it costs more it must be better.'
Where the real world data doesn't support that contention @ all.
Please show us the real world data. I want to see the 10K+ OCI used oil analysis on dino. I want to see the real world pump and flow data on conventional 10w30 at -20°F. I want to see all the sludge engines with synthetic at 7.5K miles. If you make contentions that there is no difference at all, then prove it with real numbers.
I'm not defending this guy, but criminy you start beating on him mercilessly for his writing skills. And the same people doing the beating complain about lack of data being used on BITOG. Interesting.
If dino works for you, use it.
Since conventional oil is cheaper, no need to run it 10k+ ocis.
Mobil tried that with their Mobil 1 Extended Performance and it was a marketing joke IMO.
Who is saying that you should run 10w30 @ 20 below? (I have in a few engines and they are still running)
That is what 5w30 is for.. It works well. (I think it gets cold here. My sister in Montana uses 5w-20 and 5w30 and it gets REAL cold there. No problems in her 93 Caravan with 200+K, 2003 Taurus or 1994 F250 (it actually uses a diesel 5w-40).
I want to see all the sludge engines with conventional @ 7.5k too.
If you talking about all the Toyota motors I'd bet (and so does Toyota) that those engines did not get 7.5k OCIs either. And some of them were not following the severe service schedule even though they were being operated in such service.
Some of them were arriving at the dealership with Sludging issues with less than 20k on them.. (and the FACTORY OIL FILTER meaning that the filter was NEVER changed, we can guess about the oil)
(In 2005 Toyota simplified the OCI. Everything gets a 6 month or 5k OCI period. No oil issues since)
At 5k OCI I'll say that it does not matter.
I've done used oil analysis on a few motors here and you've seen the data. If you want to discount the data due to it being a $20 used oil analysis, fine but I'd hope that you discount ALL of the used oil analysis no matter what oil.
I've said that if cost was no problem, I'd run Amsoil 7500 XL for 7,500 miles. But cost per mile is not close to other oils I can get. And in the end, it does not matter.
But, If I was paying full retail for Mobil 1, PP, or any other over the counter syn, I'd be buying Amsoil XL from Pabs in a sec. And if conventional oil gets anymore expensive (since the deals are gone)
Pablo will be seeing a repeat customer.
Take care, bill
PS: (Did I kiss up well enough Pabs?)
(but it is true, I've stated that in other threads folks)
