Just because 205/55 R16 94H is the XL version (instead of regular 91)!
Actually the new tires are xl rated, just forgot to mentionJust because 205/55 R16 94H is the XL version (instead of regular 91)!
The answer is tire load table. It is a standard that anybody who wants to sell tires in civilized countries adheres to.Were do you come up with this stuff? You don't even know the brand or model of tire.
Did you notice that one tire is SL (standard load) and the other is XL (extra load)?Well, I looked up those two different sizes for similar tires and they are BOTH load rated 94, 205/65/15: https://www.tirerack.com/tires/tire...65TR5WCO&vehicleSearch=false&fromCompare1=yes and 205/55/16: https://www.tirerack.com/tires/tire...HR6WCUXL&vehicleSearch=false&fromCompare1=yes Only the speed rating is different.
First I've seen or used, did I figure it right?![]()
Tire Pressure Calculator
Easy to use tire pressure calculator. Use our tire pressure calculator to calculate the new tire pressure needed when changing tire sizes.tiresize.com
Looks like
The question was load rating.Did you notice that one tire is SL (standard load) and the other is XL (extra load)?
They have the same max load but I think they achieve it at different pressures.
They are both 94 tires. 1,477 pounds on either one. So what if they achieve it at different pressures? That's easy to adjust.What are the load ratings?
"Different tires, same pressure?"They are both 94 tires. 1,477 pounds on either one. So what if they achieve it at different pressures? That's easy to adjust.
I notice that the max load for either of the tires is several hundred pounds more than what the tires are actually carrying at the recommended PSI. Would that mean that at my lower load, that I could run a lower pressure safely, to acheive a softer ride? Like the chart calls for 41 lbs, and maybe I could run 36?
When you say drive faster, what do you mean by that? I never drive over the speed limit, or is 75 considered faster? Also, I found these tires cheap, and wasn't up on all the spec's, so I guess kinda screwed up, but I will just live with it as best I can.You should really look at the loaded axle weight. it's a big hassle to set pressures every time the load changes, so max axle weight is a good starting point. getting XL tyres is not good if you wanted a softer ride as these require higher pressures to carry the same load. The inflation tables tell you what you need if you know the loads.
Also, inflation pressures need to go up if you intend to drive faster
Handling becomes sluggish aswell when underinflated. choices --> consequences.
