Once we get past the marketing hype, it seems that Mobil 1 Extended Performance 5w30 has more and/or different additives than the regular 5w30 M1. Using the search function, I didn't find any actual analysis to tell us what the differences are- did I miss a good post?
Also, presuming that someone has done the analysis and knows the chemical differences between the two types; would the additives in EP provide any advantage if the oil is changed at "normal" intervals? Or would their benefit only arise if the oil is kept in service for extended mileage?
