Difference between Maxlife and Durablend?
Durablend : one of the thinnest oil one will find in that grade , has no moly , strong sodium add pack for detergency
Maxlife : on the thicker side of the spectrum usually, has loads of moly , seal conditioners , one of my fav of all the Valvoline offerings.
BTW Durablend is going away, from here on out shortly , there will only be Maxlife.
Yep.
Durablend looks a little thinner as compared to Maxlife, assuming that the Valvoline Product Data Sheets I've looked at are of comparable accuracy.
Maxlife has some moly, while Durablend has none.
I added a quart of Durablend to my BMW 2.5K into its current run of Maxlife NG, mainly because I had some DB 10W-40 in quarts, and I figured it was a very similar oil.
Loving the MaxLife.Oil is very clean colored,still "thick" on the stick,and not leaking a bit (there was a slight pan gasket leak).I will be using MaxLife Syn Blend 10W30 from now on.
I'm very happy with Maxlife 10W-40 in the BMW.
Leaks have basically gone away, as they did with Mobil 1 15W-50, and oil consumption is a record low 2.5K/qt.
Fuel economy has averaged 32.5 mpg on Maxlife 10W-40, which also pleases me.
I'll UOA this run of Maxlife NG when it hits 4K around the end of this month.
