Quote:
Quote:
Just cause you see trucks idling all night long doesn't mean it won't hurt them. Idling is bad for diesels period. I'm surprised that you guys on an oil forum would make such a blanket statement that it's fine you should know better around here. It breaks down oil additives, increases suspended soot, and rasies acidity levels in the oil decreasing intervals. Big truck engines typically burn anywhere from .08 to 1.2 gallons per hour of idling some fleets factor in the wear damage of 1 hour idling as the rough equivalent of 500 miles rolling. So you can factor in that excessive wear with the 3$ a gallon fuel you waste every hour. Now in extreme weather conditions idling is necessary. I do it myself all the time to stay cool or warm. But that doesn't make it ok for the engine.
youre tellin me that an hour of idling is equal to 500 miles of rolling? at what speed is this being taken, 500 miles per hour? hahhahaha. 500 mile per hour semi's are equal to an hour of idling.
what you said is pretty far out there.
;ets assume at the legal speed limit of 70, it would take over 7 hours to go 500 miles. assuming this more realistic approach, how is an hour of idling (which is super low load and low stress on the bearings and rings) equal to over 7 hours of running at 70?
keep in mind at idle, diesel can be over 150:1 afr.
